power steering problems - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 11-27-2012, 04:01 PM Thread Starter
i have the 97 5.9 cummins and when i cut the engine off it pushes motor oil back through the power steering pump what can i do to fix this
howell75 is offline
post #2 of 14 (permalink) Old 11-27-2012, 06:02 PM
dieselhead29's Avatar
iTrader Score: 5 reviews
how did you diagnose that there is motor oil in your p/s fluid?
Support Our Troops and God Bless the U.S.A
'96 - G56 - S475 over Cheetah - Built
dieselhead29 is offline
post #3 of 14 (permalink) Old 11-27-2012, 07:22 PM Thread Starter
cause the oil was low but the ps was full
howell75 is offline
post #4 of 14 (permalink) Old 11-27-2012, 07:24 PM Thread Starter
u can also here pressue pushing the oil out of the power steering could the pump be going out its self
howell75 is offline
post #5 of 14 (permalink) Old 11-27-2012, 07:35 PM Thread Starter
and when u try to turn the steering it whines and when u hit the brakes it whines im just saying this is what it is doing i dont really know what it could be it does have a vaccum pump and has hydro boost brakes
howell75 is offline
post #6 of 14 (permalink) Old 11-28-2012, 09:25 AM
So, do you physically see engine oil in your power steering reservoir? How low was your engine oil? P/S reservoir holds little fluid. If you lost engine oil enough to notice it and it migrated through the vacuum pump to your p/s pump, it would be flowing out of your p/s pump.
1995 Ram 4X4 12V bone stock original (at this time), 47RH, KDP mod accomplished (finally)
bandsdean is offline
post #7 of 14 (permalink) Old 11-28-2012, 11:27 AM
Having just replaced my PS pump, I sympathize with you. There's a seal on the pump, that if loose, could theoretically let engine oil into the pump. My pump would completely drain out in 3 days just sitting, even with all hoses replaced.
There are two rubber seals (o rings) internally behind two of the hose fittings that you can't see, and in my case the PS fluid would drain out.
I doubt that its engine oil displacing PS fluid, but it does sound like pump is out.
The chain remans ( NAPA, O'reilly, et. al.) are junk. I went through 2 NAPAS, until I found a local shop that specializes in Power steering pump rebuilds ($68). Maybe they ship (Raven Power Steering Specialists, Denver, CO, 303-777-6640).
The stealer wanted $720 for a factory new one, and the mopar4less wanted $450. Rockauto is cheap remans too, so if you've got a local shop like Raven, I recommend the 2 man shops that still care about their work.
97 2500 4wd, AT, 3.54, 560k +, stock except for AFE filter and BD steering brace.
deezldude is offline
post #8 of 14 (permalink) Old 11-28-2012, 11:46 AM
This is for a 24v but is similar to a 12v
The Following User Says Thank You to bandsdean For This Useful Post:
canyonkid (01-16-2013)
post #9 of 14 (permalink) Old 11-28-2012, 01:31 PM Thread Starter
bandsdean it is coming out through the ps and the oil was about 1.0 gallon low
howell75 is offline
post #10 of 14 (permalink) Old 11-28-2012, 01:40 PM
Now I'm leaking oil too, and it's coming out where the PS pump goes into the vacuum pump. I should have replaced that seal!
post #11 of 14 (permalink) Old 11-28-2012, 02:45 PM
I also wish I would have seen that youtube video several posts above!
post #12 of 14 (permalink) Old 11-28-2012, 05:02 PM Thread Starter
yea theres a seal there but mies coming from the ps cap
howell75 is offline
