p7100 fuel pressure - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 09-03-2012, 09:05 PM Thread Starter
fastrider450r's Avatar
p7100 fuel pressure
My girl friend has a 95 12V, (see my signature for mods), we are running her fuel pressure guage off of the top of the stock fuel filter. She has a raptor 150 lift pump. Once we installed the guages the fuel pressure is only reading 12psi at idle, and when you stand on the throttle it reads almost "0". My questions are 1) What is the correct Idle, and WOT fuel pressure she should be showing. 2) Can I achieve the correct pressure with turning up the fuel regulator on the raptor lift pump?
Im not to savvy with the 12 valve engines, but the motor is pretty decently built and I would think it needs a lot more pressure than that.
thanks for the help.
12' 2500,3.73,G56,CC/LB Laramie,Black,ARP,H&S MM,Flo Pro,AFE,Valair DD, Airdog, 100hp nozzles, ATS dual fuelers w/cp3k, 2nd gen Steed speed w/S467, MCCBYRYAN.
fastrider450r is offline
post #2 of 5 (permalink) Old 09-03-2012, 09:39 PM
Sasquatch
crazyrunner33's Avatar
The P7100 is designed for 35 PSI, some people have had better luck running 40-45 PSI. The factory lift pump usually puts out around 20-25 PSI at idle and up to 35 PSI under load, that's if the rest of the fuel supply system is up in good running order.
I'd first check to make sure the overflow valve is the correct one needed for an electric lift pump, Tork Tek sells the one needed for an electric lift pump. The fuel regulator adjustment might work if that's the problem, but this could be related to a bad overflow valve or something else in the fuel supply system.
Joe G's fuel system writeup
'97 ECLB NV4500 compound mufflers, Banks stacked with Edge Juice w/Attitude, throttle sensitivity booster, lockup switch, wastegate delete
'10 VW Golf TDI DSG, High Performance DPF, low friction timing belt
crazyrunner33 is offline
post #3 of 5 (permalink) Old 09-03-2012, 10:04 PM
You might have a restricted fuel filter
dieseldemon is offline
post #4 of 5 (permalink) Old 09-04-2012, 11:23 AM
levi_plummer's Avatar
Sounds to me like Either a pump for a 24v truck or a bad over flow valve.. The over flow valve can be moddified with a pen spring.. But on my 175 pump i had i ran 60psi.. 160 and 175hp pumps are known to have a lazy cam which does allow adequate fill of the barrels. If they dont fill all the way then you lose lubrication in them which can make plungers stick or crack a barrel. Neither are an easy fix.
92 W250 SCLB fresh Buit motor, Billet 47re, Maxed 215, 5'ks, 26*, 5x22's, 165lb. valve springs, 188/220, ported head, S480/92/1.10, ATS manifold, 2nd gen intercooler and radiator, traction bars, fuel boss & dual feed 578/1087 on the old setup.
levi_plummer is offline
post #5 of 5 (permalink) Old 09-04-2012, 11:56 AM
Nor'Easter's Avatar
Are you using a fuel pressure gauge isolator?
Mike-97 2500 5spd.-5x.012s-3GSK-Usual pump stuff-Fluidampr-Stock Timing- 310/784 9/15/13 SOLD
97 F350 OBS Fummins-getting VE/NV4500 and frame-off and TWINS. SOLD
1957 Dodge Power Wagon 12v/NV5600/Coilover and Air Suspension
Nor'Easter is offline
