1 Ton Wheel Adapters - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 09-02-2012, 07:31 AM Thread Starter
I am converting my 94 from SRW to DRW, bought 2 sets of front adapters from guys on the forum and neither will bolt-on. The recess machined in the inside of the adapter is approx 1/8" too small diameter (4.600"). It doesn't match the wheel center hole size like the outside. The outside where the wheel bolts on is the correct size (4.77"). I wonder if it would be safe if I put them in the lathe and machined the recess out to fit?
2004 (early) 2500 2wd QC, 50hp injectors, Holley Black pump, HTS valve body,DPC converter
1994 2500 2wd 5-speed RCLB, #5 Plate, 4k GSK, 60# Springs, 035 del. valves.
1996 Ford E-SuperDuty Bus, 1991.5, 5R110 trans, HE351, 3200GSK, THD pin, M&H spacer.
dbshelton is offline
post #2 of 5 (permalink) Old 09-02-2012, 12:56 PM
JeepsRcool's Avatar
Why would it matter WHO puts them in a lathe and opens them up?
If you send them back and they open them up, or you find a machine shop to open them up, OR like you said you open them up. The end result is all the same. But I would never run spacers to run dually wheels, I would change to the dually hubs.
1995 Dodge 12v ECLB Auto 4X4 240k KDP Tabbed, BHAF, 7x.012's, 16*s
JeepsRcool is offline
post #3 of 5 (permalink) Old 09-02-2012, 06:15 PM Thread Starter
I didn't get my point across. They are the Dodge factory cast iron front adapters, not some aftermarket units. Looks like there was a change in 2000. Possibly this was the difference?
post #4 of 5 (permalink) Old 09-03-2012, 07:54 AM
DOH !!!!!
bluemule95's Avatar
I don't what that would hurt...you're only talking about 1/32nd all the way around. Just make sure you only take off what is needed and no more. My front spacers have to be gently persuaded to come off......
95 clubcab 3500 4x4 dually,built 47rh tranny,exhaust,posi front and rear,leveled,235x75x16 tires,dd,215k plus, gauges,afc modified and tuned,#0plate,scotty type air box,borgsen steering....slow but pulls...
bluemule95 is offline
post #5 of 5 (permalink) Old 09-04-2012, 07:08 AM Thread Starter
I went ahead and machined the spacers to fit. Went for a 20 mile drive yesterday and no wobble or shake. Removed the wheels and re-torqued the nuts. May do it again after about 100 miles or so just to be safe.
