dodge and ford dana 80 axles interchange - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 08-03-2012, 12:58 PM Thread Starter
smokincummins89's Avatar
Hey guys I have been looking around and couldn't get a forsure answer but I was wondering if a axles shaft out of a dana 80 from a ford will fit into a dana 80 from dodge. The axle I need is from a regular dually so if you have any input I would greatly appreciate it
Thanks
Jake
smokincummins89 is offline
post #2 of 3 (permalink) Old 08-03-2012, 11:16 PM
country_hick's Avatar
I have read where shafts are defined by how many teeth are on the end that goes into the pumpkin. If the teeth are different then they will not fit. If the teeth are the same count it is time to measure and see if they are the same.
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
post #3 of 3 (permalink) Old 08-04-2012, 04:27 PM
rockin345's Avatar
wish I could answer you, guess you will need to pull your axle and measure it, count the splines and shaft diameater. Maybe you can search the dana webs ite, or currie or someone like that. Here is some info from yukon gear, just differentials and east coast gear. Good Luck, that was a 5 minute or less internet search.
SKU: YA D47847-2
YUKON GEAR & AXLE
Dana 80 35 Spline AXLE SHAFT
40.24 " LONG , 8 X 4.02" Bolt Pattern
Broken axle? Welcome to the club! Whether you use your truck for daily driving, towing, sled pulling, or drag racing, upgrading your axles will alleviate the risk of leaving you stranded or coming in last place.
Applications
Compatible Differentials:
Dana 80 - 35 Spline
Dana 80, 98 & newer Ford only - 35 Spline Differential
Regular Price: $0.00
OPP Price: $200.26 With your purchase, receive at no cost:
Quantity:
Compatible Make / Model:
Chevrolet / Chevy C3500 (1999 - 1999)
Chevrolet / Chevy Express Van 3500 1 Ton (1992 - 2001) Chevrolet / Chevy Express Van 3500 1 Ton (1992 - 2001)
Chevrolet / Chevy G30 1 Ton (1992 - 1995) Chevrolet / Chevy G30 1 Ton (1992 - 1995)
Chevrolet / Chevy P30 1 Ton Van (1997 - 2005) Chevrolet / Chevy P30 1 Ton Van (1997 - 2005)
Chevrolet / Chevy P3500 (1997 - 1999) Chevrolet / Chevy P3500 (1997 - 1999)
Dodge Ram 2500 3/4 Ton (1993 - 2002) Dodge Ram 2500 3/4 Ton (1993 - 2010)
Dodge Ram 3500 1 Ton (1993 - 2002) Dodge Ram 3500 1 Ton (1993 - 2010)
Ford E-350 1 Ton (1988 - 2010) Ford E-350 1 Ton (1988 - 2010)
Ford E-450 (2000 - 2005) Ford E-450 (2000 - 2005)
Ford F-350 1 Ton (1988 - 2005) Ford F-350 1 Ton (1988 - 2005)
Ford F-450 (1999 - 2005) Ford F-450 (1999 - 2005)
Ford Super Duty F-350 1 Ton (1999 - 2010) Ford Super Duty F-350 1 Ton (1999 - 2010)
GMC K30 1 Ton (1992 - 2000) GMC K30 1 Ton (1992 - 2000)
East Coast Gear
http://eastcoastgearsupply.com/c-271...le-shafts.html
Rear Dana 80 Chromoly Axle Shafts
Home Catalog AXLE SHAFTS Rear Axle Shafts Rear Dana 60/70/80 Axle Shafts Rear Dana 80 Chromoly Axle Shafts
East Coast Gear Supply - Rear Dana 80 Chromoly Axle Shafts
Just Differentials
http://www.justdifferentials.com/ind...Path=25_53_487
96 2wd eclb 47re stock 434,000 miles
- new oil pmp, kdp, Fluid damper, curt 24k 5th whl.
Twin Electric Fans, Glowshift Gauge, 2004 Alum 17 wheels, continuous maintenance
rockin345 is offline
