My Tork Tek adjustable OFV review - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 07-26-2012, 08:03 PM Thread Starter
Whats up guys? Ive had my truck for 4 years now and ive been getting the mod bug here lately. I figured id start with the simple stuff first and then work my way up. I decided to buy the Tork Tek adjustable OFV. Well, i am surely glad i did. It took about 30 minutes to install (like a dummy i bent the line so i had to bend it back which is the reason it took so long DO NOT BEND THE LINE TO GET IT IN OR OUT!!!!!!!). I havent put much miles on the truck since i installed it. The few miles that i did drive was a MAJOR improvement on the truck. Taking off from the line is 100000000x better than with the stock OFV (mileage unknown on mine, could be original). Before when i hit the gas on take off it was like Lag, lag, lag, lag lag and about 1700 RPM it would take off. Now when i hit the gas (not even WOT) it just takes off. I also had an issue when i hit the gas and let off fast the truck would damn near stall out and the rpms would drop, that problem seems to be cured as well. I am so impressed with this product i wanted to share it with those who HAVENT put one on their truck yet. The best 50 bucks ive spent on the truck so far. Just thinking about it makes me want to go drive the truck, it was a totally different monster and my truck is all stock except for a billet TC and rebuilt transmission. For those of you that havent heard of this product or need to know where to get it TORK TEK CUMMINS ADJUSTABLE OVERFLOW VALVE OFV010 - Tork Teknology
Thanks,
Johnas
96 12v, ECLB, KDP KILLED! 5'' straight, 3kGSK, #100, afc mods, Fuel, Pyro, Boost gauges, Fuel heater MIA, TorkTek adj OFV, GM 1 ton, Dacco billet TC, Kevlar bands, billet accumulator, billet 3 piece servo, HD band strut, BW solenoid and TransGo TFOD
Shadow7g is offline
post #2 of 8 (permalink) Old 07-26-2012, 08:45 PM
I would say the Tork isn't better than a stock OFV but it's better than any OFV that isn't working right which is what you had.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #3 of 8 (permalink) Old 07-27-2012, 05:06 AM
flubyux2's Avatar
So I didn't see any mention of the fuel pressure. Did this not require adjusting to set your fuel pressure?
I just stretched my spring for the time being. Took it to 0.650" overall length.
truck #5
2001.5 3500 Laramie, qclb, 4wd, drw auto, goose, AirRaid
flubyux2 is offline
post #4 of 8 (permalink) Old 07-27-2012, 08:14 AM
I went through a similar process, didn't know about the spring streching possibility. Installed guage, found low pressure ( 7-15) ordered an ofv from a different vendor. Cheaper though. why waste money. Installed it, maxed my 30 pound isspro. woops should have ordered the 60. Which I did. pressure slowly went down over the few days it took to recieve the new guage. ( 14-20) replaced lines cleaned filters, throughout the system. finally ordered the TT adjustable valve, and the pressure is back to where it is supposed to be. It has stayed there and I suspect I'll get a lot of mile out of it. For the OP, read the newbee posts and get your guages started so you can keep your truck going as long as possible.
97 3500, single wheels and m103a bed. 4x4 Jasper tranny w/ Goerend VB , single TC and pan. isspro Gauges. 1993 GMC/zuzu4000 dumper, JD790 lots of attachments.
Axtell3 is offline
post #5 of 8 (permalink) Old 07-27-2012, 10:06 AM Thread Starter
No gauges to tell at the moment. Those will be next. I just ordered the transgo shift kit, sonnax billet accumulator, the patc billet servo, hd band, and borg warner pressure switch and new oem pressure sensor so my budget is low right now
Sent from my SCH-I510 using Tapatalk 2
Shadow7g is offline
post #6 of 8 (permalink) Old 07-27-2012, 12:29 PM
did your tork teck comewith a ball and spring i just received my and all i got was the banjo fitting and 2 gaskets
97 4*4 4 inch exhaust no muffler or cat cpp 4gsk 60lbs valve springs 100 plate 024 dvs sac 5x16 injectors tuned afc volant cold air fass 165 gph pump isspro gauges hamilton cam 62-65-14 over s475 ar 1.32 arp studs tork teck 50hp rack plug sitting on 35 mickey thompsons
racerfreak is offline
post #7 of 8 (permalink) Old 07-27-2012, 12:40 PM
dieseldemon61's Avatar
Did you get the adjustable one? The ball and spring should be inside the banjo fitting
1995 2500 auto, tuned afc, #0 fuel plate, air, tabbed kdp,180 pump swap, afc spring kit, #4 governor spring kit, 21* timing, fullcut dv's, 120. holders, rack plug, oversized fuel lines, 60/65/16, 120hp injectors, 60lb valve springs, water meth
dieseldemon61 is offline
post #8 of 8 (permalink) Old 07-27-2012, 04:29 PM
no its the 50 hp one no spring and ball
