How well does the block heater work? - Dodge Cummins Diesel Forum
Old 03-07-2008, 04:47 PM   #1 (permalink)
J_T
HEy all...I don't live in real cold...mid 20s would be coldest but in 30's can be normal. But I just started using my block heater for cold starts.
When I do. the "Wait to start" light goes out quicker so Something is working...but I don't see any change in my Temp gauge or how fast the heater blows. Buddies talk about it blowing hot air when they get in and crank it. (they may be hot air).
Maybe Mine is doing what it should?
What do you all get out of it?
Thanks
JT
1996 Ram 2500, 90hp DDP, DV's, 12V, 5sp, 4wd, Extended cab
J_T is offline   Reply With Quote
Old 03-07-2008, 04:53 PM   #2 (permalink)
CumminsFan04's Avatar
Shouldn't be blowing hot air on start up. The block heater just makes it easier on the motor to start it in the morning and it does warm up faster too once you start driving it compared to it not being plugged in at all.
Also, you won't notice a difference in the temp. gauge either on start up.
'03 Acura RSX Type S
Bolt ons...
-Domestic killer.
CumminsFan04 is offline   Reply With Quote
Old 03-07-2008, 04:56 PM   #3 (permalink)
paulm85's Avatar
It helps to bring the temp of the block up (obviously) but that will warm the fluids...oil and coolant and that will make the start up process much easier on the motor and in my experience will make the heater blow warm not hot depending on how long it is left on. It is good policy to plug in at temps below 50 in my opinion
New ride:
2011 F-350 6.7 CC/SB Lariat loaded....just hope its as good as the dodge
Previous Ride
'05 silver 2500 CTD auto, laramie, 4x4, Just a simple farm truck...def gonna miss that truck
paulm85 is offline   Reply With Quote
Old 03-07-2008, 04:57 PM   #4 (permalink)
Yellowstone's Avatar
This winter has been terribly cold in WY, many times not getting above -10 for weeks at a time. I plug in my 07 and unless it is below -10 or -15 I don't get the wait to start all the time. The heater is not hot but but slightly warm, usually.
Yellowstone is offline   Reply With Quote
Old 03-07-2008, 04:57 PM   #5 (permalink)
Buck08's Avatar
All t really does is keep the oil warmer for easier cold starts.
10 Laramie C/C Shotbox
02 Excursion Limited TS 6 pos
95 2500 2wd project
Buck08 is offline   Reply With Quote
Old 03-07-2008, 05:17 PM   #6 (permalink)
J_T
Well its making it easier to start...so I guess its doing its job!
Old 03-07-2008, 06:21 PM   #7 (permalink)
The block heater heats the coolant. It will make your engine reach operating temps faster and make your cab warmer faster as well as cutting engine wear on startup. Costs about 6 cents/hr in electric cost(in Maine) so if you put it on a timer and use it about 3 hrs before start up it probably saves $$$ over longer idle + warm up times with the current price of diesel.
1995 Ram 4x4 2500 Long Bed, AFE Magnum Force, EGT, Boost, Tranny Temp Gauges, Killer Dowel Pin repair, Jerico FG Cap, Fisher Minute Mount Plow
scrinch is offline   Reply With Quote
Old 03-07-2008, 06:44 PM   #8 (permalink)
ynots57's Avatar
Thanks
JT
Have you tried sticking a thermometer in the tail pipe and see what the temp is j/k sorry, couldnt help myself.
Some morning pop the hood and feel the top of the engine. They dont get what you would call hot. There is some heat there that is why the grid heater doesnt stay on as long. The only time Ive seen any heat inside the cab at startup was on a ford 6 cyl. gasser with a circulation style tank heater.
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline   Reply With Quote
Old 03-09-2008, 01:13 AM   #9 (permalink)
Bomaster238's Avatar
next time you plug in the truck let it sit for about an hour and go out and see how warm the engine block is. it makes a difference haha.
94 12valve 5 speed.5" single stack,AFE intake,Holset H1E, bosch 370s, TST #6, Schied Diesel DVs, HD valve springs, FASS150 A-meter Pyro and boost, boost elbow, KPD killed,16.5*, 550hp clutch on the way, leveling kit, 35s
Bomaster238 is offline   Reply With Quote
Old 03-09-2008, 09:17 AM   #10 (permalink)
ISX
ISX's Avatar
I never feel any heat on mine.. Only time I did was when I left it plugged in for 24 hours.THEN I finally felt a warm radiator hose... I am told a cummins 8.3 heater will heat the hell out of these so I might get me one. The my ford plugged in for 8 hours will get the coolant over 100F (seeing as how my high idle never kicks on and it turns off at 112F leading me to believe it must be getting that hot)
1990 F250 7.3 IDI NA auto 4x4 250k
1997 2500 12V Cummins 5spd 2wd 322k miles #100 plate, SB Con O, 26.6MPG-55mph
ISX is offline   Reply With Quote
