more responsive after disconnecting TPS??? - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 06-09-2012, 07:40 PM Thread Starter
I have had this scenario occur a few times now, and I'm scratching my head as to why/how it's happening....
So I disconnect the TPS (throttle position sensor) and remove the 2 bolts holding it on, put it back on and reconnect the plug, fire the truck up and the throttle response is much better. Feels like I'm driving a different truck, has a lot more pep and doesn't feel so sluggish.
After I shut the truck off and start it again it's back to its sluggish self. Any ideas?
'97 12v 4x4
a2rags is offline
post #2 of 8 (permalink) Old 06-10-2012, 12:45 PM
dylon_333's Avatar
Fill out your signature so we know what truck your workin on. I'm not sure what your actually unplugging?
Sent from my iPhone using Autoguide
06 quad cab 6 speed swap with dual disk clutch edge juice with attitude for gauges with efi! 5 in exhaust! 2nd gen style mani, 63/68/12, 2 inch leveling kit
96 single cab short bed 5 speed bored out. big plans for this truck!!!
dylon_333 is offline
post #3 of 8 (permalink) Old 06-10-2012, 10:36 PM
zthatzmanz28's Avatar
I would trash the TPS (unplug and forget about it) and hook up a POTS...
You are probably experiencing a phantom type surge when the TPS is disconnected / reconnected. After shut down the TPS resumes normal malfunction.
1998 2500 4X4 CTD QCLB 3 inch lift-- Stablizer Bar-Tork Tek OFV-MAXX links-KDP TABBED-Luke's Link & Bushing POTS LMC dash #10 fuel plate AFC ISSPRO fuel- boost-2K* PYRO BHAF Posi-Loc Larry B Solenoid & relay rebuilt 47re low stall TC
zthatzmanz28 is offline
post #4 of 8 (permalink) Old 06-10-2012, 11:20 PM
country_hick's Avatar
Most car computers lose everything in memory when the battery is disconnected for a few minutes. It takes them awhile to relearn how to give the best mpg for a given drivers driving pattern. Maybe this is what is happening with the tps input?
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
post #5 of 8 (permalink) Old 06-10-2012, 11:49 PM
jnicewan's Avatar
TP sensor is only used on auto trans trucks and/or trucks equipped with EGR. For auto trans trucks it only provides input for the torque convertor clutch and 4th gear shifting. EGR trucks its used to help regulate EGR flow along with ECT and IAT. I dont see how it could affect throttle response at all, unless maybe you have an EGR truck.
98 12v, 48RE, Revmax kit, V/B, triple disc stage 5, ultra low stall with a few other billet pieces. AFC modded, 100ish plate, 16.5ish*, KDP gone, 60lb springs, 4K-GSK, BHAF, pyro, trans, boost guage. , 72 AM general M35A2 LDT465
jnicewan is offline
post #6 of 8 (permalink) Old 06-11-2012, 10:37 AM
Considering what the TPS controls on a 12 valve the only thing that makes sense is you are temporarily "fixing" a bad connection by unplugging the sensor or just moving the wires around.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #7 of 8 (permalink) Old 06-13-2012, 12:57 AM Thread Starter
yea, I thought it might be plug/wiring related, but the wiring seems to be in great shape along with the plug, i've also tried messing with the plug after the truck goes back to being sluggish and it hasn't made a difference. only seems to get peppy if I actually remove the TPS altogether. I don't get it.
'97 12v 4x4
a2rags is offline
post #8 of 8 (permalink) Old 06-13-2012, 09:09 AM
glfredrick's Avatar
Then you have an issue related to the transmission as that is the only thing the TPS controls. No other electronic controls on the engine.
1995 D2500 4x4: #10 fuel plate, BHAF, turbo orfice, AFC forward, 3000 GSK, pyro & boost ga. NEXT: trans ga & filt, 4" exhaust, billet TQ, valve body.
UCORA.org -- United Christian Off-Road Alliance.
glfredrick is offline
