Replacing injection pump need timing help!! - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 05-17-2012, 11:55 PM Thread Starter
levi_plummer's Avatar
Hey everyone I am about to replace the pump on my 95 motor and am needing help. I understand most everything other than setting the motor and installing the timing pin in the pump gear under the pump and setting up the piece that goes in the side of the pump.. (I read and saw it in my Haynes manual) the part that I'm lost on is if I change the pump timing. How would both the timing pin under the pump and the fuel injection timing pin in the side of the pump line up If I have the injection timing advanced... It might just be one of those things I am getting ahead of myself on but any help is appreciated... Thanks!
92 W250 SCLB fresh Buit motor, Billet 47re, Maxed 215, 5'ks, 26*, 5x22's, 165lb. valve springs, 188/220, ported head, S480/92/1.10, ATS manifold, 2nd gen intercooler and radiator, traction bars, fuel boss & dual feed 578/1087 on the old setup.
levi_plummer is offline
post #2 of 11 (permalink) Old 05-18-2012, 12:18 AM
95cummins5.9's Avatar
time the pump where you want it using the engine to turn the pump, then pop the gear, then put the engine a tdc. if you have a dial indicator kit , forget the pump even has a pin IMO. also it is worth the time and little effort to find tdc using the drop valve method in the tech articles...trust me on the drop valve
95 RCLB 5 speed 4x4 440,000. plate slid, afc mods, DAP 230's BHAF 18*
97 ECLB 5 speed 4x4 370,000. 100 plate, afc mods and tuned, natural aspiration lol currently, smokem 5x14s, 7mm d.v.,20*,BHAF
95cummins5.9 is offline
post #3 of 11 (permalink) Old 05-18-2012, 12:23 AM
were the timing pin goes into the pump the plate it slides into is adjustable, if you wanted to set the pin up when you have the pump off the truck (easiest) dial indicate the disired timing loosen the two bolts on the plate and move it so the pin slides in. your pump would be pin timed at (??*)
post #4 of 11 (permalink) Old 05-18-2012, 11:27 AM
Read the tech articles> 94-98 Tech Articles - Dodge Cummins Diesel Forum
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #5 of 11 (permalink) Old 05-18-2012, 01:01 PM Thread Starter
Originally Posted by illflem View Post
Still doesn't help me. My timing is adanced to 20.5 degrees I'm trying to find out how to swap pumps without setting my timing to stock on the new pump.... I.e. if I swap this tump and set the pump to TDC without putting the piece in the cam gear when i pull it out. If I set the new pump to TDC with it be timed at 20.5 degrees too if both pumps are pin times at 20 degrees from the factory? Thanks
post #6 of 11 (permalink) Old 05-18-2012, 02:56 PM
schueller74's Avatar
You have to pin the engine then pin the pump bolt it on and go through the timing procedure. Different pumps have different timing / plunger lift settings.
96 2500cclb 4x4 NV4500 Lots of goodies
schueller74 is offline
post #7 of 11 (permalink) Old 05-18-2012, 08:42 PM
If both the old and new pumps are timed to 20 with the pin on the side of the pump locked then the new one will stay at 20 as long as you don't turn the crank at all between removal and installation.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
post #8 of 11 (permalink) Old 05-19-2012, 08:50 AM
blackimpala's Avatar
Will this help you?
Timing in 40 minutes (P7100)
Floyd
blackimpala is offline
post #9 of 11 (permalink) Old 05-19-2012, 10:09 AM Thread Starter
We set pump at TDC and put the pin in the pump and popped it off the crank when I put the new pump I'll make sure it's pinned when I tighten the nut.
post #10 of 11 (permalink) Old 05-19-2012, 11:46 AM
thats what i'd do...
1990 F-350 with a '92 cab and bed and '85 front clip. P-pumped 12 valve (marine pistons and injectors, Hamilton cam, 60lb springs, FASS fuel system, ARP head studs and HX40)
ZF6 Trans and nv273 being installed now. Dash replaced with all autometer.
cjhstang is offline
post #11 of 11 (permalink) Old 05-19-2012, 11:49 AM
iTrader Score: 7 reviews
the pin in pump itself is set whether it be factory specs or if you have had a pump shop mess with it they will change it if you advance the timing beyond the pump specs then the TDC pin and pump pin will no longer line up those pins are for a starting point to advance it for example if your pump is set to 11.5 degree timing when both the pump is pinned along with the TDC pin your engine will be at 11.5 degrees which wopuld be your starting point then you advance it from there to your desired spec this will no longer allow the pins to be pinned at the same time they are for reference of stock specs if you set to say 17 degrees then later on decide to got to 20 degrees advanced its good practice pinn time the motor back to stock then advance it to 20 dgrees advance instead of gong from 17 to 20 if this makes any sense to you
twisted_diesel is offline
