semi upgraded 47rh vs nv4500 - Dodge Cummins Diesel Forum
Old 05-08-2012, 07:08 PM   #1 (permalink)
95twelvecummins's Avatar
Im new to this forum so sorry if I'm starting an old thread up again, still trying to get use to this forum. Which seems to be more of a better idea semi building a 47rh or just dicing in and doing a nv4500 swap? i wouldn't mind doing the swap it just i don't want the truck being all mix matched with wiring and all the small things like tack and speedo not working. i have a quote of $3200 for a full nv4500 swap but idk which is a better idea. if anyon has input it would be greatly appreciated. Thanks..
95 cummins NV4500 swap. stock fuel plate slid forward and star wheel turned, AFC housing Full Forward and Anroid screw turned a little. but its not stock screw lost stock one ha
95twelvecummins is offline   Reply With Quote
Old 05-08-2012, 07:13 PM   #2 (permalink)
Nor'Easter's Avatar
There's no real wiring to be done. Just safety switch and reverse light wire. Tach and speedo is unrelated.
What do you mean by quote? It's something anyone can do really, with the right tools and some time. I'm collecting parts for my swap and all in after I sell my 47re I'll be around 3k with a brand new trans and 500hp clutch. Just need to source around and wait for deals.
Mike-97 2500 5spd.-5x.012s-3GSK-Usual pump stuff-Fluidampr
97 F350 OBS Fummins-getting VE/NV4500 and frame-off.
Nor'Easter is offline   Reply With Quote
Old 05-08-2012, 08:15 PM   #3 (permalink)
thanks for the fast reply what brand clutch are you going with? and is there any sites or anywhere particular your getting your parts from? i kinda have to jump into mine due to the fact the tranny is leaking pretty good and its slipping a good amount too. Thanks
Old 05-08-2012, 08:16 PM   #4 (permalink)
quote i ment a guy in VT has a full swap with I'm guessing used clutch and the front and rear drive shafts for $3200
Old 05-08-2012, 08:53 PM   #5 (permalink)
EVRE's Avatar
Not to hijack, but would a G56 bolt in as well?
White 2012 Ram 2500 Long Box Crew Cab Laramie, CTD, G56, 3.73, 4x4 <Sim Deleted> Nitto Trail Grapplers 285/75R17
EVRE is offline   Reply With Quote
Old 05-08-2012, 09:10 PM   #6 (permalink)
Nor'Easter's Avatar
Yeah I've bought some stuff from him. You don't need driveshafts, and honestly shop around for things. I'll be in less than that with an reman NV4500 and 500hp clutch... 3200 isn't really a great deal.
G56 is a lot bigger and will not bolt in. You'd need cross members reworked as well as adapters in the bellhousing/engine adapter area or things.
Old 05-08-2012, 09:47 PM   #7 (permalink)
GAmes's Avatar
iTrader Score: 5 reviews
That is partially correct. The crossmember does have to be reworked, or you could do a 2" body lift. The G56 bolts up to the same block that holds the NV4500 and the auto trans. I went with a one piece flywheel and a Southbend Clutch, but I suppose you could use a duel mass flywheel and the stock type clutch/flywheel if you desired. It is a swap that will only really benefit you if you do a lot of towing.
97 3500, 2 WD, G56, slightly bombed, 980,000+miles
GAmes is offline   Reply With Quote
Old 05-08-2012, 11:21 PM   #8 (permalink)
I thought 95's had tO have diffrent driveshafts for them. And where have you found your reman nv4500 and the clutch from?
Old 05-08-2012, 11:38 PM   #9 (permalink)
zenzen_427's Avatar
Like said before G56 will mate just fine. Need a custom crossmember which would be nice if you ever had to drop trans (no more splitting the frame!). Idk about transfer case. Drive shafts will have to be modified.
More fuel than air... 550hp
zenzen_427 is offline   Reply With Quote
Old 05-08-2012, 11:43 PM   #10 (permalink)
Yeah even with the nv4500 theyd have to be too. Any idea were to find reasonable priced nv4500 or nv5600?
Old 05-08-2012, 11:50 PM   #11 (permalink)
zenzen_427's Avatar
I got a rebuilt nv4500 and transfer case for 800 to my door. Gotta look for the deals. I have an extra nv but it needs a mainshaft, 5th gear, and nut at the bare minimum.
Old 05-09-2012, 04:21 PM   #12 (permalink)
yeah i been looking around. i called a well know tranny shop in my area today and the manager gave me a ruff estimate $3500-$4000 for a semi built auto tranny, triple disc converter, shift kit, valve body and full rebuild.
