Ofv? - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 04-27-2012, 02:10 PM Thread Starter
kfisher's Avatar
Ofv?
I am looking to buy a tork tech ofv but I'm not sure which one (040,060, adjustable...) I am trying to get rid of a problem that has been happening where my truck loses power coughs white smoke spit sputters loses boost until I back off the throttle (usually only at wot) I think pensacola fuel Injectors are to blame but before I buy new Injectors I want to do the ofv, fuel filter, and pre filter
Sent from my ADR6300 using AutoGuide.Com Free App
97 EC, LB white, smoked cab lights, 4 inch skyjacker firestone bags and 37s on 17s. afc tuned, #0 slid where it needs to be, boost elbow @ 37lb, BHAF, 4 inch straight pipe to 6inch single stack, 100hp injectors, gauges (boost/egt) valair single 450hp 850lb ft
kfisher is offline
post #2 of 7 (permalink) Old 04-27-2012, 02:15 PM
98-6BTA's Avatar
It's been so long since I've bought mine I forget the exact "number" but it is adjustable, but is preset at around 32PSI. It's performed flawlessly for me so far, I really need to get a fuel press. gauge.
98 12V auto 3.55 230K+miles, BHAF, Full 4" exhaust,AFC tuned just right.boost/pyro, 7 Blade HX35, 5x.012 Con. injectors,48RE trans with suncoast tripple disk TC koleene steels and trans-go shift kit, Tork Tec Adj. OFV
98-6BTA is offline
post #3 of 7 (permalink) Old 04-27-2012, 02:22 PM
pic_jon's Avatar
DETAILS OF EACH TORK TEK OVERFLOW VALVE - Tork Teknology
97 12v 2wd project: Dual-Fed 913 by Seth | 148* 7x.010" | 351cw/475/92/1.1 | Valair DD
pic_jon is offline
post #4 of 7 (permalink) Old 04-27-2012, 03:51 PM Thread Starter
kfisher's Avatar
Thanks. Will a non adjustable work?
kfisher is offline
post #5 of 7 (permalink) Old 04-27-2012, 04:02 PM Thread Starter
kfisher's Avatar
The link picjon put up explained that the 040 and up ofv were for fass and air dog applications but the 010-020 were for stock and bio fuel apps. What if I am not stock or bio but don't have fass can I still use 040
kfisher is offline
post #6 of 7 (permalink) Old 04-27-2012, 05:59 PM
zthatzmanz28's Avatar
Call Rob at Tork Tek. He loves to talk and can direct you to the right OVF.
1998 2500 4X4 CTD QCLB 3 inch lift-- Stablizer Bar-Tork Tek OFV-MAXX links-KDP TABBED-Luke's Link & Bushing POTS LMC dash #10 fuel plate AFC ISSPRO fuel- boost-2K* PYRO BHAF Posi-Loc Larry B Solenoid & relay rebuilt 47re low stall TC
zthatzmanz28 is offline
post #7 of 7 (permalink) Old 04-27-2012, 08:39 PM
The one at the bottom is best> Overflow
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
