12v MPG - Dodge Cummins Diesel Forum
post #1 of 20 (permalink) Old 03-11-2012, 10:49 PM Thread Starter
ipooted205's Avatar
12v MPG
so i have a 95 2500 cummins with 3.55 gears and a k&n air filter (drop in). their is no mods done to this truck, but i think someone has played wit the star wheel. im not a heavy foot driver i just recently put 150 miles on my truck city and highway mixed and i only got 10.23 mpg. the highest i ever got was 12 even all highway. can their be a major problem with my truck?
1995,2500, 4X4, AUTO, 3 INCH STRAIGHT PIPE, #10 Fuel plate, KDP Tapped, AFE Stage 1 Intake System, silencer ring M.I.A. NEXT:5 inch turbo back with 6 inch tip,tint windows,paint, and body work.
ipooted205 is offline
post #2 of 20 (permalink) Old 03-11-2012, 10:53 PM
Dans12v's Avatar
Thats horrible. Check for a leak. My 92 WIF censor o-ring leaked till I found it.
97 2500 CCLB 223k, he351ve man cont, 4", airdog, 51" donaldson
2012 QCSB 2500 g56 35k stock, first clutch at 25k, second at 35k. SAC is horrible
Dans12v is offline
post #3 of 20 (permalink) Old 03-11-2012, 11:00 PM
Bully Dog Technologies
BdLyle's Avatar
check for boost leaks by all the couplers, intake, turbo ect.
06 Mega|69SXE/83mm|RKL Trans|DDP Super Mental Injectors|AD-200|PPE Dual CP3/dmax pump|Bully Dog Custom Tune||On3 Intercooler|Fleece Coolant Bypass|1050HP/1802TQ 12.56@98MPH
BdLyle is offline
post #4 of 20 (permalink) Old 03-11-2012, 11:02 PM Thread Starter
ipooted205's Avatar
i have benn looking i think i have found a small leak on my injection pum, but i dont know how to tighten it up, is thier a special way to do so?
ive uploaded a pic where is seen some fuel possibly leaking out of.
post #5 of 20 (permalink) Old 03-11-2012, 11:03 PM Thread Starter
ipooted205's Avatar
well if i did have a boost leak wouldnt m boost gauge be off? i can hit 27 boost np.
post #6 of 20 (permalink) Old 03-11-2012, 11:04 PM
Dans12v's Avatar
Go through and check to make sure all the nuts and bolts are tight.
Dans12v is offline
post #7 of 20 (permalink) Old 03-11-2012, 11:07 PM Thread Starter
ipooted205's Avatar
well i will tommorow today i degreased my engine and washed it so ill look tommorow if i see any leaks, i just want better mpg lol.
post #8 of 20 (permalink) Old 03-11-2012, 11:07 PM
BdLyle's Avatar
it wont affect the readings at all of the gauge. I use a rubber end cap then put a tire stem through the middle of it so i can pressurize the system with an air compressor. I have found leaks in so many small places that i would never have found.
v
BdLyle is offline
post #9 of 20 (permalink) Old 03-11-2012, 11:12 PM
estrada5.9's Avatar
Check your timing
1998 QCLB
2003 QCSB
2010 QCSB
estrada5.9 is offline
post #10 of 20 (permalink) Old 03-11-2012, 11:14 PM Thread Starter
ipooted205's Avatar
v
ill have to try this. thanks. my buddy has a 92 12v and he never goes below 20mpg.
post #11 of 20 (permalink) Old 03-11-2012, 11:34 PM
jtheado's Avatar
As said above, check your timing. Also the injectors might be due for replacement based on the miles. If its an auto, they don't due the greatest. Get a lower stall tc and shift kit, that will help a bit.
98 2500 12V|170K Miles|#0Plate|AFC MIA|HX35|Raptor 150|TorkTek Airdog OFV|Isspro EV Pyro/Boost|KDP Fixed|47re Stock|FBD 5"|BHAF
08 Chevrolet 3500 CCLB DRW|50k Miles|LTZ|100% Stock
jtheado is offline
post #12 of 20 (permalink) Old 03-11-2012, 11:42 PM Thread Starter
ipooted205's Avatar
Well I only have 165000 miles on it and yeah it's an auto and it's going to need to be rebuilt because its really bad
