Turns over, but won't start when hot. - Dodge Cummins Diesel Forum
post #1 of 25 (permalink) Old 03-10-2012, 08:30 AM Thread Starter
SootyCND's Avatar
I did a search and found nothing. Anyways, here is the deal. Starts fine when cold. Batteries are spanking new.
When it reaches operating temp, if I shut her off and try to start it back up right away, she turns over like the batteries were weak.
-All wires are clean and have di-electric grease on the connectors.
-batteries are brand new.
If I wait a half hour, she fires right up with no problem.
So:
-Leaky injector(s)?
-Bad timing?
-gripping piston rings?
I am stumped!!!!
1995 auto. Stock plate re-installed and pushed forward
, AFC pushed forward. Got gauges too!!! BHAF installed, KDP behind bars. More to come!!!!
SootyCND is offline
post #2 of 25 (permalink) Old 03-10-2012, 08:57 AM
Mine used to do the same thing. Turns out injection pump was needing replaced. I was always told the next time it does it dump a bucket of cold water on the ip and if that solves your problem then that's it.
Sent from my PC36100 using AutoGuide.com App
98 12valve 4x4 , 8 inch cat stack, little pump work, little trans work
Still too slow
bcrule1 is offline
post #3 of 25 (permalink) Old 03-10-2012, 09:00 AM Thread Starter
SootyCND's Avatar
Even if it's 5 deg F outside? I would understand summer, but cold Kanuksistan winter?
SootyCND is offline
post #4 of 25 (permalink) Old 03-10-2012, 01:08 PM
Mine did it in the winter. Not sayin that has to be your problem. Does it try and run or just won't at all?
Still too slow
bcrule1 is offline
post #5 of 25 (permalink) Old 03-10-2012, 06:18 PM
might be the starter getting hot
1998 2500 12v cummins 4x4 auto "5 speed waiting to go in" quad cab.
1991.5 2500 auto 12v going on 5 ton Rockwells and rice and canes.
cobramustang331 is offline
post #6 of 25 (permalink) Old 03-10-2012, 06:28 PM Thread Starter
SootyCND's Avatar
Starter is brand new!!!
SootyCND is offline
post #7 of 25 (permalink) Old 03-10-2012, 06:29 PM Thread Starter
SootyCND's Avatar
Thanks for the answers guys. I will try the cold water or snow trick. If it's not that, put my huge starter contacts in my 1 year old starter.
SootyCND is offline
post #8 of 25 (permalink) Old 03-10-2012, 10:22 PM
What brand of starter did you put in?
good for reading about starters just in case
Won't start!
http://fostertruck.com/dodge/
97 2500 4x4,cold air intake,Proflow 4",355's,5sp,100 fuel plate,autometer guages,tuned to EGT's,KDP done,steering box stabilizer,285x75x17 Villians with bfg mudders
12valvecanadian is offline
post #9 of 25 (permalink) Old 03-11-2012, 06:46 AM Thread Starter
SootyCND's Avatar
Won't start!
LarryBs.com Dodge
Read that when I had problems about a year or two ago. Thanks for the heads up though.
I guess I'll post a video!!!!
SootyCND is offline
post #10 of 25 (permalink) Old 03-11-2012, 01:41 PM
Sounds like the pump. You need to verify that you have adequate fuel pressure to the pump. Be sure you have changed the filter too.More than likely though the injection pump is worn. Had a tractor that would not start when warm and the water trick would work to get it going but it is very hard on pump internals.
1997 Dodge 2500 3/4 ton ext. cab 4x4 5sp., Dana 80 rear, 3:55 gears, Dual 5 inch stacks, 116,000 miles
farmboy1989 is offline
post #11 of 25 (permalink) Old 03-11-2012, 07:44 PM Thread Starter
SootyCND's Avatar
Lift pump, filter, heater and all that stuff is brand new. Holding 30 p.s.i on fuel pressure!!!
Sounds like a freagin plunger issue damnit!!!
SootyCND is offline
post #12 of 25 (permalink) Old 03-12-2012, 01:08 AM
blackcummins95's Avatar
mine does that every now and then i have to turn the key on and then go manualy pull up on the fuel shut off solenoid and then she will fire up....
95 3500 nv5600 conversion
2011. Mega Cab 2500 4x4 stock 70,000 miles
blackcummins95 is offline
The Following User Says Thank You to blackcummins95 For This Useful Post:
E30Newbie (09-21-2013)
