having issues fuel issues... i think - Dodge Cummins Diesel Forum
Old 01-23-2012, 08:12 PM   #1 (permalink)
I am having some major issues with my truck. It is a 1994 12v auto 4x4. I drove it to work this morning and had no issues at all. After getting off work i went to start the truck, no issues yet. out of no where it stalled out. It fired right up, and when i put it in gear it stalled again. When i tried to start it a third time it smoked really really bad, whiteish blue. a buddy said that it could be gelled up so i poured a bottle of diesel 911 in the tank, and put a 50\50 mix into a new fuel filter. it would then only start with the help of a TINY shot of ether. when i ran it through the rpm range it would randomly miss. the miss was not at any particular rpm point. my friend cracked a few lines and it seemed to be getting fuel to all injectors. if i really put my foot in the accelerator and then let up on it it would idle fine for a few seconds, maybe 15 seconds, then miss a bit and stall out. the truck has about 230k on it with, as far as i know, original injector pump, lift pump, and injectors. what areas should i be looking at first?
1994 Dodge 2500, reg cab, 4x4, auto, 12v
1996 dodge 1500, extended cab, 4x4, auto, 360
funky187 is offline   Reply With Quote
Old 01-23-2012, 08:43 PM   #2 (permalink)
DM1970's Avatar
Not sure on the starting issue but do yourself a favor and never use ether, its best to use a spray silicone that's flammable. You may have already known that and used ether in a pinch but I figured I would throw that out there just encase.
1995 Ram 2500 12V NV4500 4x4
DM1970 is offline   Reply With Quote
Old 01-23-2012, 10:23 PM   #3 (permalink)
If your truck is working right ether can literally blow up when used. There is a grid heater in in the intake manifold. Think of it like a toaster in there. When you squirt ether on that hot glowing metal it can easily go "BOOM" and break something expensive.
Hopefully others will chime in here. From what I have read maybe your timing slipped. Absolutely check your filters. You may have a clogged filter that would cause problems.
1997 3500 club cab Automatic 3.54 gears towing and camper package. Still stock with 116k on it so far. 4" dynomax stainless exhaust, 4kgsk, and pacbrake exhaust brake waiting for installation. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is online now   Reply With Quote
Old 01-24-2012, 06:42 AM   #4 (permalink)
I will not use ether any more. Thanks for the heads up. How common is it for the timing to slip? How do I check and adjust?
Sent from my SCH-I500 using Tapatalk
Old 01-24-2012, 10:55 AM   #5 (permalink)
Anyone else have an idea?
Old 01-24-2012, 11:00 AM   #6 (permalink)
12valvedriver's Avatar
Check the tech section. There is a write up for advancing your timing as well as setting it back to stock. Does sound like a timing issue though to me.
Sent from my DROID X2 using Tapatalk
'97-5" straight #100 ff, 19*, 4k gsk, valair dd clutch, 1-3/8" billet input, ARP studs, 60# springs, BD Super B over s475, 024's, Mayville WI best 5x14's,
'90-4" exhaust kdp killed
12valvedriver is offline   Reply With Quote
Old 01-24-2012, 12:09 PM   #7 (permalink)
Super Moderator
Joe G's fuel system writeup
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
Old 01-24-2012, 01:08 PM   #8 (permalink)
We can get the truck to run, it just has an occasional miss. And it won't idle. I will look into the timing. Thanks for that link, it is super helpful. The part that gets me is I havent really had any issues until yesterday, what causes the timing to be off?
Old 01-24-2012, 01:15 PM   #9 (permalink)
Super Moderator
It slips due to the way the timing is adjusted, by moving a tapered shaft on a tapered gear with no key to keep it from moving.
Only a clean surface and sufficient torque keeps it from slipping.
Bill
'95 2500 4wd auto
Stock for one day
Old 01-24-2012, 02:16 PM   #10 (permalink)
Is this a common issue?
Old 01-24-2012, 02:37 PM   #11 (permalink)
P.J
P.J's Avatar
You need to (try) ti eliminate fuel issues first.
I had these same symptoms, prefilter on the bottom of the fuel heater was jammed with black crusty san'ish looking material.
If you don't KNOW the history of the fuel system and/or don't know your fuel pressure you need to:
1) Replace lift pump (easy and cheap)
2) Replace OFV (also, cheap,.... easier)
3) Delete fuel heater and clean/replace prefilter (free/cheap, EASY)
4) Visually check all your lines for leaks, this usually isn't the problem with your symptoms, but WILL cause hard starts and other issues.
5) Replace fuel filter at some point throughout these steps.....
6) Get a fuel pressure gauge, in cab preferably.
I can't say this IS your problem, but eliminating it from the equation is a one evening and a few hundred dollar process (max).
P.J is offline   Reply With Quote
Old 01-24-2012, 05:10 PM   #12 (permalink)
Super Moderator
Yes, but doesn't sound like your problem.
Just a fuel pressure gauge will saving you from throwing needless parts at it.
You don't need to get fancy just for diagnostics, a $10 gauge from the hardware store will work fine.
Instructions> http://www.cumminsforum.com/forum/94...-12-valve.html
and> Low Pressure Fuel System Diagnostic Procedures
Bill
'95 2500 4wd auto
Stock for one day
