nv4500 grinds going into 3rd - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 01-05-2012, 12:02 AM Thread Starter
I searched the treads and I think I have my problem figured out just want some opinions I just did a auto to nv4500 swap and put a new valair clutch kit and slave cylinder and filled it with factory mopar fluid about 150 miles ago and I drove the truck on Sunday which was about 45-50 degrees and it shifted flawlessly. I parked it on Sunday and got in on Wednesday which was about 11 degrees and got about 5 miles from my house and went to down shift from 4th-3rd and it grinded and little but went into gear i thought I may of not had the clutch pedal in enough but then it started grinding shifting from 2nd-3rd and will only go in if I let the rpms drop then it goes in smooth and stays in and now down shifting is impossible from 4th-3rd all the other gears 1st, 2nd,4th,5th, and reverse work fine and go in smooth would 3rd gear syncros go out just like that or is something else wrong? I also drained the transmission today and took the pto covers off and cleaned it all out and topped it off with 5 quarts instead of 4 this time to see if it would make a difference and I helped a little bit on the upshifted part but still grinds but it did not help the down shifting do u guys think itís the syncros or just the cold weather? Any tips or info would be great thanks guys
96 2500 4x4 RCLB k&n cold air intake, MBRP 4" exhaust, 4GSK, #10 fuel plate, isspro boost,egt,fuel pressure gauges, nv 4500, valair 13" clutch , 3.55 gears limited slip
96cummins12valve is offline
post #2 of 12 (permalink) Old 01-05-2012, 02:07 AM
I had that problem.. new syncro and it was good.
Maxed 12mm pump, nv4500 w/ Valair DD, 35'' BFG on 3rd Gens, S300 Borg Warner, 12mm ARPs, BHAF, A-Pillar gauges and bad case of ITS
DC9612V is offline
post #3 of 12 (permalink) Old 01-17-2012, 08:54 AM
check your master/slave cylinders..if they are good its a bad 3rd gear synchro. double clutch shifts until you can rebuild the trans.
1998 QCLB 12v 2500 4x4 5spd
Scotty II intake, 304 stainless 4" TBE, #10 plate FF, Isspro boost & EGT guages, 43psi
Rowingfish87 is offline
post #4 of 12 (permalink) Old 01-18-2012, 01:47 AM
TowMan59's Avatar
mine has been doing that for a while... im just double clutching it and not let my crazy woman drive it till i go fuller
97 dodge 3500 5.9 12v dually RWD 5sp no plate tickled afc daily driver/workaholic
Dodge owners for Fuller Transmissions:
TowMan59 is offline
post #5 of 12 (permalink) Old 01-18-2012, 03:47 AM
wheres a good place to get a rebuild kit for the nv4500?
sledheadak is offline
post #6 of 12 (permalink) Old 01-18-2012, 04:19 AM
just grind it till you find it!
mike
2011 mega
itspaid4 is offline
post #7 of 12 (permalink) Old 12-02-2012, 09:52 AM
99cumminsmoke's Avatar
What did this cost to fix mine is doing the same thing. Grinds just going into 3rd at higher rpms.
99,2500,eclb,nv4500,5 inch straight mbrp,s&b cold air,EJ w/a,AIRDOG 150,150 injectors,sb dd,ARP,188/220 cam, super b special,cobra 29 lx,lots of lights,leveled,eagle 186 rims,cowl hood.
99cumminsmoke is offline
post #8 of 12 (permalink) Old 12-02-2012, 10:11 AM
xcountryguy04x's Avatar
east coast gear supply
2007 Ram 2500 QCLB, 5.9, Billet everything 48re, HTS valve body, ATS 5 Star, Fass150, ATS Dual Fuelers, ARP 625, ARP mains, Hamilton 103#, Hamilton 178/208, Fluidampr, BMS 100's, 362/475, EFI Live, Edge Insight CTS
xcountryguy04x is offline
post #9 of 12 (permalink) Old 12-02-2012, 02:51 PM
catmike's Avatar
mine does the same i just shift easier into third till i can get it fixed
97 3500 ext cab 4x4, nv4500, banks power pack
catmike is offline
post #10 of 12 (permalink) Old 12-02-2012, 08:00 PM
Lol mine does too.. Its worse when trying to shift quicker though. I just shift from 2nd to 3rd slow and easy like a big rig now
1994cumminshp is offline
post #11 of 12 (permalink) Old 12-03-2012, 01:33 AM
mine is the exact same way if i hold it and 2100 for a second or 2 and then let off it will slide right in but if i just shift normally it grinds going in on the up shift hoped it was a clutch issue but just installed a valair dual disc yesterday and no change been doint it for over 12,000 mikes and hasnt gotten worse so im not gonna worry about it
96 2500 4x4 nv4500 5 inch
No smoke yet is offline
post #12 of 12 (permalink) Old 12-03-2012, 06:57 PM
My truck was like this when I got it... found a NV4500 for a good price (because it had the same issue), put a 3rd gear syncro, put 5th gear nut fix on it, went through the rest of it (looked good), and swapped it... then fixed the one out of my truck & sold it.
not hard to do, but there are some specific tools you'll need.
seems common enough that I now double-clutch going into 3rd just to keep from wearing it out.
1998 QC 12V NV4500 4x4 LB w/ CM flatbed, #10 plate, timing 16deg, Timbren load boosters.
Lunyfringe is offline
