instructions for replacing governor pressure sensor? - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 11-29-2011, 01:37 PM Thread Starter
smote's Avatar
Getting ready to order the governor pressure sensor and HD governor pressure solenoid off of ebay from Cascade. Was hoping someone here has replaced these before and can offer some tips and possibly instructions.
I've had the pan off before to change the filter and trans fluid so I just need to know what to do from there. thanks.
1996 dodge 2500 2wd extended cab, automatic, indy 500 edition.
smote is offline
post #2 of 7 (permalink) Old 11-29-2011, 05:33 PM
1bad12r's Avatar
Dodge Cummins Automatic Transmission 48re Gov Pressure/Transducer Solenoid Replacement - YouTube
hope this helps
1996 auto 3k gsk auto meter gauges dpc reman converter
1bad12r is offline
post #3 of 7 (permalink) Old 11-30-2011, 07:30 PM
4x4flatbed's Avatar
its cake, first thing i did to my first cummins because it wouldnt shift right. once you get the filter off you will see a little bracket with the solinoid in it and its just r&r from there. good luck man
1997 eclb 2500 4x4, nv4500, southbend 3600dd w/1.375 shaft, maxed 180 pump, afc mods and no plate, 20*, conta!gous 5x14s, 024s, 4k gsk, 64/71/13, 5" tbe, airdog 165, tork tek 060, ARP studs and o-ringed head, guages, 2" level, 16x12 with 33s
4x4flatbed is offline
post #4 of 7 (permalink) Old 12-01-2011, 05:37 AM Thread Starter
smote's Avatar
thanks for the help. I'll get parts on order and do this over the Christmas shutdown.
smote is offline
post #5 of 7 (permalink) Old 12-01-2011, 06:12 AM
Click > 1996 DODGE RAM FACTORY SERVICE CD-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
If you are going to work on your truck, you need one of these.
RPegram is offline
post #6 of 7 (permalink) Old 03-14-2012, 11:22 PM
bmart's Avatar
iTrader Score: 7 reviews
Subscribed for the YouTube video
2006 Cummins:
S366 with 2nd gen swap,BMS 50 horse injectors,
4" MBRP exhaust, EFI LIVE by Anarchy Diesel
bmart is offline
post #7 of 7 (permalink) Old 03-14-2012, 11:51 PM
Tflight's Avatar
They are easy to change but id get genuine MOPAR parts from yer local dealer. Theyll last longer. I put on the cheaper onesin before just, asken for issues, just my 2$.
95 4x4 2500,BHAF,4in MBRP turbo back ex,afc mod's,custom plate half way,boost elbow,SDX 5x12 stick's,HX35/40 hybrid,15 deg,isspro gauges,3ks,upgraded valvebody w sonnax goodies,dpc billet 3 disc low stall,kdp pinned.
Tflight is offline
