Won't start after fuel filter replacement - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 11-28-2011, 08:34 PM Thread Starter
Hi, I just changed the fuel filter and the truck will not start. In the past it has started after a fuel filter replacement without having to manually bleed this system. This time I had to bleed the system, I was able to get a solid stream of fuel from the bleeder with no air, manually priming the system. The fuel shutoff solenoid is lifting. The motor did fire a few times but would not stay running, and that was with depressing the accelerator while cranking.
In the process of re tightening the bleeder screw to make sure it wasn't leaking, I did manage to strip out the bleeder screw. It is all the way closed but It appears to be leaking a small amount of fuel. I don't believe it is enough of an air to keep the motor from firing. I am guessing that is going to be a dealer only part?
Thoughts on what the problem could be other then the bleeder screw?
Truck is a 96.
bigdreamin is offline
post #2 of 7 (permalink) Old 11-28-2011, 08:45 PM
I've seen bad lift pumps show up right after a filter change.
What happens is the injection pump will suck fuel from the tank on it's own but once some air gets in it won't prime on it's own.
Dealer or Cummins for the bleed screw.
It will probably leak more with the engine running.
Big problem is air will get in the system when the truck is parked making it hard to start.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #3 of 7 (permalink) Old 11-28-2011, 10:39 PM
gary502's Avatar
get yourself a lift pump and a good bleeder screw....my lift pump sh1t out right after a fuel filter change....
95 2500 4x4 5 speed, reg cab, 12 valve, 90hp injectors, fuel plate DELETE, 5'' stacks, 35" nitto terra grapplers, valair single disk (looking for a double).
gary502 is offline
post #4 of 7 (permalink) Old 11-29-2011, 01:33 PM Thread Starter
I'm not entirely sure that it is the lift pump, however it does have 330K on it and it is the original pump. I will probably replace it regardless, seems like I have far exceeded the life expectancy of the original unit. Not to mention I already have to make a trip up to Cummins anyway to get the bleeder screw. I also know the fuel heater is still on and the prefilter screen as never been cleaned. So the fuel heater will go in the trash and the screen cleaned as well. I also plan on replacing the 5/16" return line behind the fuel filter as well as the 1/2" line from the prefilter to the lift pump. Both of those are original so they most likely need replaced as well. Since the fuel filter has to come back off for that I am also going to check the tightness of the water sensor/drain. I went a 1/4 turn past finger tight, should have been tight enough.
The lines from the tank to the motor have been replaced with braided stainless lines. So I shouldn't have a problem there.
Only thing really left would be the sending unit.
post #5 of 7 (permalink) Old 11-30-2011, 12:31 PM
moparnut72's Avatar
Lift Pump
330k on a lift pump? Holy Cow. Mine was out at 140k. I didn't know it at first. Truck was down on power so I figured I needed to change the filter. That's when I discovered the pump had failed. I was told at the time that that is the usual life expectancy.
kk
moparnut72 is offline
post #6 of 7 (permalink) Old 11-30-2011, 01:26 PM Thread Starter
kk
Yup, and as it turns out the lift pump is still good. I cleaned the prefilter bleed the system, using compressed air and then the manual bleeder and she fired up and runs fine now.
post #7 of 7 (permalink) Old 11-30-2011, 01:30 PM
I'm at 290k miles with the stock pump in my 3500.
The 2500's pump went out at 220k.
If I didn't have fuel pressure gauges in both trucks I probably would have replaced the pumps just as preventative maintenance long ago.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
