Life expectancy of a P7100 - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 11-12-2011, 09:44 PM Thread Starter
kingjohn1027's Avatar
I know there are a lot of variables that determine the life of an injection pump, but I am just curious to see when other people have had to replace or rebuild their P7100. I have close to 200k miles on the original injection pump. I always use some type of additive to enhance lubricity and always keep the filters changed on a regular basis, but anything made my man will fail at some point. I have heard the p7100 pumps are very robust, but how many miles can one take before needing new barrels and plungers, delivery valves, etc?
1996 2500 2x4, 12v cummins, 192k miles, auto tranny, long bed, stock besides transmission upgrades and plan to add a little more power.
kingjohn1027 is offline
post #2 of 16 (permalink) Old 11-12-2011, 10:48 PM
Welp, there's a number over a million miles. A couple of weeks ago, I personally drove one that's over 800k. In fact, the STOCK AUTO TRANS in that truck is also over 800k! If that's not a record, it must be close. Anyway, pump life from normal wear just isn't a factor on these engines. Your hands will probably wear the rim off the steering wheel first.
'98 12v 2wd dually, SB DD, Detroit locker, 64/65/13 htb2, CPP 7x10's, 3kgsk, bhaf, 19*, 50 lbs boost
v8440 is offline
post #3 of 16 (permalink) Old 11-13-2011, 12:06 PM
i also have two of them with over a 1,000,000 miles on each and one truck with a highly modified pump when the truck was new in 1998 none of our p pumps have ever needed work except for a fuel shut off solenoid
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets
carl48 is offline
post #4 of 16 (permalink) Old 11-14-2011, 01:59 PM
I was reading about a taxicab in Greece with a Mercedes diesel P- pumped with 3.6 million miles on it.
Lots of parts had been replaced or rebuilt but not the P- pump.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #5 of 16 (permalink) Old 11-14-2011, 11:10 PM
i must be pretty unlucky, my 95 went at 175000 barrels were warped
95 cummins, stock automatic w/ shift kit, 5" turbo back, swiss cheese airbox, 3kgsk
twelveV95 is offline
post #6 of 16 (permalink) Old 11-15-2011, 09:50 PM
GAmes's Avatar
iTrader Score: 7 reviews
Originally Posted by kingjohn1027 View Post
I always use some type of additive to enhance lubricity ..........
That money would be better spent on beer. I had my IP repaired at 750k because of an oil leak where the throttle rod sticks out on top. Not one fuel lubed part needed replacement. I never use additives, but I do drink beer.
97 3500, 2 WD, G56, slightly bombed, 1.2 million miles. Started the second million on 8/24/13
GAmes is offline
The Following User Says Thank You to GAmes For This Useful Post:
lastcall190 (11-16-2011)
post #7 of 16 (permalink) Old 11-15-2011, 10:46 PM
'89dodge's Avatar
wow i wonder if the other injections pump can last that long
2016 Chevy 1500 LT Z71 ccsb all stock 5.3 6speed 3.42.
2011 ram 1500 SLT 2wd she gone, not missed.
'89dodge is offline
post #8 of 16 (permalink) Old 11-16-2011, 12:57 PM
moparnut72's Avatar
Beer
I never met a beer I didn't like, some just better than others.
kk
moparnut72 is offline
post #9 of 16 (permalink) Old 11-16-2011, 01:05 PM
Broke Down
mongo800's Avatar
kk
People often ask me what brand i drink, to which i reply, OPB(other people's beer).
Mongo
2012 2500 Mega Cab Laramie, Flame Red over Grey, 68RFE, 2" Rough Country leveling kit, stock.
1998 12Valve QCLB, 4" MBRP Turbo Back, BHAF, 13" Valair Kevlar/Ceramic, No fuel plate, Autometer Pyro, Boost, Fuel, Banned 5x14 sac inectors, 63/68/14 pushin 54 lbs
mongo800 is offline
post #10 of 16 (permalink) Old 04-13-2012, 12:05 PM
DionysiosA76's Avatar
Its actually a M-Pump... same thing though. My uncle has 1.2million KM on our 2.4D Toyota Hilux in Greece.
07 5.9 G56 Creater of FB phenomenon "Because Pull Truck" 12.79@109
Valair|SteedSpeed|ARP|Wicked Diesel|EFILive|Exergy|Dan's Diesel Performance|AMS Oil|Hellman|E.D.|AirDog|Ton of stuff that you can't buy
DionysiosA76 is offline
post #11 of 16 (permalink) Old 04-13-2012, 07:43 PM
ykdave's Avatar
around 500k on my original, replaced it with a used one that a buddy had sitting on the shelf (it had 2 plungers stuck from improper and lengthly storage) and it was good for another 30k, but its now starting to stick a plunger randomly
ykdave is offline
post #12 of 16 (permalink) Old 04-13-2012, 11:22 PM
God prefers Diesels's Avatar
Is it now....*rubs villainous beard while thinking*
What does the engine do when it randomly sticks? And how long does it last? Does it just vibrate a little very briefly?
93 Chevy with '97 215 47rh 241DHD HE351cw/bht3b(26cm) Con7x12tagious
Originally Posted by billow99 View Post
i hate nv 4500s i keep breaking the cluster gear. even with cryo treating. its pointless to expect them to hold up to any abuse.
Originally Posted by randemelissa View Post
You want smoke? throw a rag in your air filter inlet. you want power? we'll help all we can.
God prefers Diesels is offline
