Transmission keeps down shifting - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 11-09-2011, 12:24 AM Thread Starter
Hummin cummins88's Avatar
i recently had a problem evolve in my transmission,i have a 97 12v and a 47re ats stage II trans i just bought last year, when im cruising around 35-40 mph anytime i let off the throttle it downshifts and you can feel it dragging slowing me down, then i give it gas an it shift back up... could this be a Solenoid? any help would be much appreciated i would like to fix asap , getting really annoyed
Hummin cummins88 is offline
post #2 of 3 (permalink) Old 11-09-2011, 06:31 AM
I would give ATS a call and talk with one of their techs. Since they built it, they should be able to walk you through what to test.
RPegram is offline
post #3 of 3 (permalink) Old 02-11-2012, 05:06 PM
AU2500's Avatar
My trans is doing the same thing. Was told it could be the governor solenoid and pressure switch. I replaced those this week and it's still doing the same thing. Anyone else have any suggestions on the fix.
The Daily Driver: 2014 2500 4x4 Laramie Maximum Steel.
97 2500 4x4 auto ext cab, 285 tires and the rest is stock as a rock. SOLD.
AU2500 is offline
