rebuilding 94 looking for max power but still good too drive daily and pull gooseneck - Dodge Cummins Diesel Forum
Old 11-02-2011, 04:01 PM   #1 (permalink)
lost my license truck was ready to take a , it was burning oil and and using water starting too get loose in the bottom end trany was about gone. Wanna rebuild drive train too the max but keep it reasonable. Drive daily pull goose neck loaded too 30k and not have too stair at my gauges. I have a auto trany at the moment not sure weather im a keep it or not considering its a over the road truck. clutch gets old after awhile.Where do i begin from top too bottom at a reasonable price. looking for all ideas and input thanks
94 cummins smoker is offline   Reply With Quote
Old 11-02-2011, 04:35 PM   #2 (permalink)
Look at this first. Beginners Thread - Read First!
The automatic can be built tough with some money. I would contact some of the transmission builders once you decide what to do for power levels. The more power you add and the heavier towing you do changes what is needed when beefing up the transmission.
Then again, you can ask a big truck garage about getting a 6 speed Allison for your dodge it may be cheaper than building yours up all the way and it has 2 more gears.
As far as power levels I think I read up to about 450 hp is relatively inexpensive. After that it starts to add up very quickly.
1997 3500 club cab Automatic 3.54 gears towing and camper package. Still stock with 116k on it so far. 4" dynomax stainless exhaust, 4kgsk, and pacbrake exhaust brake waiting for installation. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline   Reply With Quote
Old 11-02-2011, 06:08 PM   #3 (permalink)
Company Name
12VNick's Avatar
You can build 500 hp pretty reasonably (after the trans is done). I would go with a 62/65/14 charger (good spool up with mild injectors and the 14cm housing will keep egts low), a good aftermarket manifold, 100 hp inj, head studs, grind the fuel plete your self, adj the afc housing, and a set of 191 dvs and you will be between 450-500 range. Reliable for towing, pull a decent load pretty good, and you should still do ok on the fuel economy side of things. Hope this helps
www.alligatorperformance.com
95 Dodge Ram 2500
12VNick is offline   Reply With Quote
Old 11-04-2011, 09:58 AM   #4 (permalink)
looking for more internal advice
