Allen plug question - Dodge Cummins Diesel Forum
Old 11-01-2011, 10:12 PM   #1 (permalink)
Allen plug question
hey guys i got my truck alittle bit ago ( 94 dodge 3500) and i just noticed my big allen plug on my pump is gone.. would that cause anything horrible? dont seem to notice anything but in the process of trying to get another one right now..
94_12 Valve is offline   Reply With Quote
Old 11-01-2011, 10:27 PM   #2 (permalink)
95duallysmoke's Avatar
Could get oil contamination.
95, 5sp 3500, 4:10, afc mods, custom intake, 4k gsk, 60lb valve springs, Home built water/meth, fuel plate lost, 2095 plug, 25* timing, Valair single. HTT SS 64/65/13 and some 7x10's NEEDING A LIFT PUMP
95duallysmoke is offline   Reply With Quote
Old 11-02-2011, 06:26 AM   #3 (permalink)
12valveterror's Avatar
iTrader Score: 9 reviews
when mine went mia it squirted a little oil out of it, but no big deal, good luck finding one, try a bosch/diesel/fuel injection shop.
Engine: Mahle "Marine" Pistons, Balanced Rotating Assembly, ECD Cam, O-Ringed Block, Ported/O-Ringed Head, 3 Angle Valve Job, ATI SuperDamper
Fuel/Air: 475cc P-Pump, 5x.014's, Airdog 150, BW 66/68/14
12valveterror is offline   Reply With Quote
Old 11-02-2011, 11:12 AM   #4 (permalink)
TB1
If you tow anything and the boost pressure is high it will puke oil out everywhere ask me how I know............ I lost about 5 liters of oil, The first thing I did when I got home was get a new plug. In a pinch you could use the small plastic cups that come on the ends of hydraulic hoses
1996 extended cab ED 62/68/13 ss with race cover, 4" BD exhaust and intake Contag!ous diesel 5x.014 injectors,.024 delivery valves, 100 plate 4gsk, AFC mods, Mack rack plug,timing @ 15.5*Head studs Isspro gauges
TB1 is offline   Reply With Quote
Old 11-02-2011, 12:11 PM   #5 (permalink)
I know how that is. The whole underside of my truck is covered with oil. But its from my afc housing bolts never staying tight. But I think I fixxed that problem. Thank you loctite
Old 11-02-2011, 03:33 PM   #6 (permalink)
USARMY12V's Avatar
I modded my AFC and realized the day after I forgot to put the plug back in it. It wasn't anywhere to be found. I looked under my truck and there was a anodized steel plug that looked roughly the same size so I crawled under there and got it. Went back up and BAM perfect size. Now I can use a 3/4" wrench to take it off instead of the 8mm. Now I don't have to tear my hand up loosening it.
98 QCLB 4x4 GT37, Contag!ous Diesel, DPC Converters. Team AirDog
USARMY12V is offline   Reply With Quote
Old 11-04-2011, 08:46 PM   #7 (permalink)
thaks guys, yea i work at a hydraulics shop and have a huge bolt bin, found one in there.
