putting a fuel pump to push to lift pump? - Dodge Cummins Diesel Forum
Old 10-31-2011, 05:08 PM   #1 (permalink)
hey so im thinking of putting a 72 gph 5-9psi pump and 3/8 or 1/2 lines to push to my lift so it has fuel readily available and doesnt have to pull it all the way from the tank. Would this be worth doing? i drop down to 12 psi at wot and would like to never see it get below 20. any ideas or thoughts on if this would work? would buy a fass but thats a bunch of money for a highschool senior at the moment.
5.9sledhead is offline   Reply With Quote
Old 10-31-2011, 06:22 PM   #2 (permalink)
Your stock Cummins fuel pump is good for 500-600 HP, you don't need another pump to "push" fuel or any fancy electric pumps. Changing out the fuel lines is an excellent idea, but again, the stock 3/8" feed line is plenty big until you start pushing some serious HP. Diagnose your pressure and repair as necessary and save your money for something else.
RPegram is offline   Reply With Quote
Old 10-31-2011, 07:57 PM   #3 (permalink)
My lift pump is only a couple months old and I get about 22 idle. And 12 wot so obviously with the fueling I have I need more or I'm starving my injection pump. Hey just a thought but would a tork tek over flow valve help it at all?
Old 10-31-2011, 08:02 PM   #4 (permalink)
Super Moderator
Highly doubt you have enough hp to drop the pressure enough to require an electric pump.
Something else is wrong.
Bad overflow valve, plugged filter or kinked hose.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
Old 10-31-2011, 11:04 PM   #5 (permalink)
Get OFV from tork teck and dont look back...When people say replace fuel line do they mean the metal fuel lines going from tank to pump? Do you get bigger rubber ones or bigger metal ones? Not meaning to hijack just curious.
Maxed 12mm pump, nv4500 w/ Valair DD, 35'' BFG on 3rd Gens, S300 Borg Warner, 12mm ARPs, BHAF, A-Pillar gauges and bad case of ITS .
DC9612V is offline   Reply With Quote
Old 11-01-2011, 12:07 AM   #6 (permalink)
Metal lines only get replaced when they get rusty (inside or out). Rubber lines can go bad without major announcements like rust on metal. If your metal lines are rusty replace them. If your metal lines are still factory black and not rusty on the inside replacing them makes no sense.
1997 3500 club cab Automatic 3.54 gears towing and camper package. Still stock with 116k on it so far. 4" dynomax stainless exhaust, 4kgsk, and pacbrake exhaust brake waiting for installation. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline   Reply With Quote
Old 11-01-2011, 03:24 AM   #7 (permalink)
ok gonna look around for a tork tek. I have no plate twin turbos mack plug 330 injectors maxed out afc and 18 degree timing and 4k kit coming soon along with 191 dvs. Is that enough to drop it lol?
Old 11-01-2011, 01:27 PM   #8 (permalink)
Super Moderator
I would never replace metal lines with metal lines.
If you use USCG fire rated diesel hose from the engine to tank it will easily last the life of the truck.
The wall thickness is about 1/2"
Bill
'95 2500 4wd auto
Stock for one day
Old 11-01-2011, 05:02 PM   #9 (permalink)
Were can you acquire this Rubber Jesus hose you speak of lol?
Old 11-01-2011, 05:44 PM   #10 (permalink)
jtheado's Avatar
With all that I'd imagine you need a fass pump depending on the size of injectors and turbos used
98 2500 12V|170K Miles|#0Plate|AFC MIA|HX35|Raptor 150|TorkTek Airdog OFV|Isspro EV Pyro/Boost|KDP Fixed|47re Stock|FBD 5"|BHAF
08 Chevrolet 3500 CCLB DRW|50k Miles|LTZ|100% Stock
jtheado is offline   Reply With Quote
Old 11-01-2011, 07:27 PM   #11 (permalink)
Super Moderator
I use Trident Barrier Lined A1-15 hose.
Google it for many sources.
Bill
'95 2500 4wd auto
Stock for one day
Old 11-01-2011, 09:30 PM   #12 (permalink)
Im totally buyin some. What size tube did you get? How did you keep it up?
