Replacing fuel lines, should I bypass the stock fuel filter? - Dodge Cummins Diesel Forum
Old 10-31-2011, 10:25 AM   #1 (permalink)
wheelin66bronco's Avatar
I'm all about filter change intervals and making it easy on myself in the long run.
The fuel suction line is leaking at the tank so I'm going to replace all lines, and the draw straw with a vulcan straw.
What is the best route to go? I'm thinking of bypassing the stock fuel filter all together and mounting a fuel filter/water separator down on the frame like an airdog but minus the pump.
What about the priming module, can that be bypassed? I'm thinking not, but I'm trying to take out anything that is known to fail. My fuel heater has been unplugged for a long time from the looks of the plug.
Look for what others have done with success.
1998 QCLB, 4x4, 12v, built 47RE, 4.10's, Toyo MT 35-17's, AFE drop-in, AFC tuned, #10 plate, 7x.009, 3K GSK, 4" exh, Guages, TC lockup sw, Free spin hubs, Bags, HID's, 223K
05 DRW free spin conversion: http://www.pirate4x4.com/forum/showthread.php?t=880388
wheelin66bronco is offline   Reply With Quote
Old 10-31-2011, 11:24 AM   #2 (permalink)
Super Moderator
Why fix something that isn't broke?
Leave the stock filter in place and use it.
The primer is part of the lift pump, no way to eliminate it.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
Old 10-31-2011, 12:54 PM   #3 (permalink)
Just do the draw straw. The rest of the system components are very robust and need little attention, except for fuel line aging. Do the fuel heater delete as per Joe G. write up.
no otto cycle is offline   Reply With Quote
Old 10-31-2011, 02:20 PM   #4 (permalink)
I really shouldn't need to do the fuel heater delete since it appears it has been unplugged for years, correct? It's the electricity that makes it fail, correct?
Old 10-31-2011, 07:43 PM   #5 (permalink)
Super Moderator
You are correct. My heater has been unplugged for years and has been no problem.
Bill
'95 2500 4wd auto
Stock for one day
Old 10-31-2011, 08:10 PM   #6 (permalink)
iHatericerockets's Avatar
Why not just delete the heater if its not being used? Its simple enough to remove or reinstall should you actually want it again
96 2500 4x4 EC LB NV4500 Stock: AFC Tuned, Boost, pyro, FP gauges, 5" Straight Pipe, BHAF, SDX II's, 4GSK, 17*, ADII 165, South Bend Dual Disk.
iHatericerockets is offline   Reply With Quote
Old 10-31-2011, 08:14 PM   #7 (permalink)
Super Moderator
It's even simpler to just unplug the heater or remove the small heater relay on the firewall.
What causes them to leak is overheating wires going into the heater.
Bill
'95 2500 4wd auto
Stock for one day
Old 10-31-2011, 11:09 PM   #8 (permalink)
Theres a delete on youtube. I did mine after watching that once, real simple and makes ya feel smart after all said and done haha. Also, dont get a straw. Ive got an ADII but thats besides the point, Look up Hellman Sump.
Maxed 12mm pump, nv4500 w/ Valair DD, 35'' BFG on 3rd Gens, S300 Borg Warner, 12mm ARPs, BHAF, A-Pillar gauges and bad case of ITS .
DC9612V is offline   Reply With Quote
Old 10-31-2011, 11:26 PM   #9 (permalink)
I saw that video, and might just go ahead and remove the heater even though it's been unplugged. Thanks for the info on the Sump, but I think I'll skip it. I do a lot of off road, brushy driving and would hate to snag that sump deal.
Old 10-31-2011, 11:46 PM   #10 (permalink)
No problem man, always trying to help and good thinkin...you sir are smart haha.
Old 11-01-2011, 08:24 PM   #11 (permalink)
FF1063's Avatar
Be prepared to suck air <1/4 tank if you park on a slope. I used the DS, nice unit, but it would have been better for me to adapt it into the oem bottom bowl assy, rather than using the straw. I plan to redo my setup.
98 RAM 3500 QC SLT 4X4 12V/CTD
05 Arctic Fox 990 Truck Camper
FF1063 is offline   Reply With Quote
Old 11-10-2011, 05:30 PM   #12 (permalink)
I ordered:
New Fleetguard fuel filter
Vulcan draw straw
3/8 diesel fuel hose
Fuel elbow hose
pressure snubber
fuel pressure guage/mount
Missing anything? I decided to not do the return hose per suggestion from Geno's, I guess just the feed line has the problems.
to Genos Garage, always very helpfull folks and good prices!!
