crankcase cover oil leak - Dodge Cummins Diesel Forum
Old 10-30-2011, 02:46 PM   #1 (permalink)
here is what i'm working on chasing down oil leak i found it was leaking from the crankcase cover and wild i was at it i reseal the vacuum pump and steering box
shortbedguy is offline   Reply With Quote
Old 10-30-2011, 02:48 PM   #2 (permalink)
CumminsCoal1's Avatar
if your front covers leaking i would do a kdp tab on it too, cheap insurance
04.5 QCLB NV5600 Pumps, Big charger, Valair triple disk, Supporting mods....
02 QCSB Dmax/Allison EFI, AD, Cognito front end, Medium charger...
CumminsCoal1 is offline   Reply With Quote
Old 11-05-2011, 07:53 PM   #3 (permalink)
crankcase cover is leaking again
Old 11-06-2011, 07:03 AM   #4 (permalink)
do you know if it leaking from the front seal or the gasket around the cover? If the motor had a lot of miles, it could be that there is a ring cut into the crank snout from the old seal. They make a sleeve that gets pressed onto the snout that makes the seal tight again.
'95 2500, mostly stock, Bully Dog CAI, 4" Diamond Eye Stainless turbo back, 3" lift, DT Track Bar, Steering Box Stabilizer and Upper and Lower control arms, '98-'99 HD tie rods, Borgeson steering box and shaft, scared of plates till i get the Trans.
wretchid is offline   Reply With Quote
Old 11-06-2011, 07:18 AM   #5 (permalink)
Just asking, but when you put the gasket on the cover did you glue it to the cover? I'm not talking about regular blue, grey or copper color type, but an actual adhesive. Also, make sure the crankcase vent is absolutely clean and no obstruction that can cause excessive pressure inside engine which can lead to failure of this particular gasket.
RPegram is offline   Reply With Quote
Old 11-06-2011, 07:12 PM   #6 (permalink)
automotiveadam's Avatar
I've heard from my mechanic friend that this is a very common problem on the 6bt's. He mostly works on the buses and other heavy equipment that uses the 12 valve
Adam-
1996 dodge ram 2500 CCLB, 4x4, laramie, automatic
4'' exhaust, KDP Tabbed, silencer ring MIA, fuel heater delete, 4.10s
automotiveadam is offline   Reply With Quote
