Thermostat Seal - Dodge Cummins Diesel Forum
Old 10-27-2011, 06:30 AM   #1 (permalink)
liamfm's Avatar
Thermostat Seal
I recently bought pn 3934373, a thermostat which is supposed to take some of the swing out of my temps. However, it came as just the thermostat and didn't come with a seal. I see on Geno's that they sell the gates thermostat with a rubber washer/seal. Does Cummins assume I should re-use the seal?
Thanks,
Liam
1998 12v QC LB 4WD - White - Tan Leather - SLT - XRF front end, DPC Single Disc, Mass Diesel Tranny Build, 5k HID's in projectors, heated powered towing mirrors, B&W in the bed, 224k miles and counting!
liamfm is online now   Reply With Quote
Old 10-27-2011, 11:23 AM   #2 (permalink)
9412valve4x4's Avatar
I just changed my thermostat and would not re-use the seal. My old seal was quite flexible and had some age on it so I put both new seals in and its leak free
94 12valve auto gauges(boost, egt, trans, and fuel press.), 5" exhaust, 370 injectors, custom delivery valves, Gutted AFC, 2095plug, Tork TEK OFV, No Fuel Plate, Airdog 200, fuel sump, 4kGSK, and 60lb springs
9412valve4x4 is offline   Reply With Quote
Old 10-27-2011, 11:38 AM   #3 (permalink)
liamfm's Avatar
crap, where can I buy a seal? Why didn't the Cummins PN come with one!
Old 10-27-2011, 12:39 PM   #4 (permalink)
It seems that that the seal comes as a separate part, least that is what has happened to me. If your old seal is flexible and clean, it can be reused. There is a product called "The Right Stuff". Buy it and use it to install the seal. The stuff is amazing. Not cheap, but worth it. You will find 1,000,000 other uses for it too.
96 reg cab, 5sp long bed 4x4: 10 plate, 3GSK, pump @15, AFC altered, K&N, gasket matched and ported exhaust manifold, 4" exhaust, gauges, KDP KO'ed, Dynatrac axles and hubs (don't go there, bad product, bad customer service), airplane landing lights, Dana Powerlok's front & rear, runs on WVO.
Baja is offline   Reply With Quote
Old 10-27-2011, 12:46 PM   #5 (permalink)
I reused my old seals, over 3 years later, no leaks.
RPegram is offline   Reply With Quote
