truck wont shift into 4th gear - Dodge Cummins Diesel Forum
Old 10-25-2011, 07:29 PM   #1 (permalink)
any ideas? it only stays into 3rd, when i swapped out the overdrive unit the speed sens was broken so i took the one out of my 2wd unit and threw it in. could that be the problems?
alextsi66 is offline   Reply With Quote
Old 10-25-2011, 08:03 PM   #2 (permalink)
dchoate2's Avatar
Man I'm in the same boat...and I've changed my tps my tc lockup and od sloenoid and the gov pressure sensor, tried a mystery switch cleaned my grounds, and all I'm still stumped except when I lost od my wait to start light came on and doesn't shut off now...
1996 dodge ram 3500, auto aftermarket tq converter, #100 fuel plate, 4 in straight pipe exhaust, BHAF, manual tc lockup switch, boost guage, egt guage..giant intake filter...
dchoate2 is offline   Reply With Quote
Old 10-25-2011, 09:51 PM   #3 (permalink)
sucks i want to be able to go faster then 45mph haha
Old 10-25-2011, 10:10 PM   #4 (permalink)
dchoate2's Avatar
Lol I can get to 55
Old 10-25-2011, 10:19 PM   #5 (permalink)
well if i find something out i will let you know first thing becase i know how it sucks!
Old 10-26-2011, 10:59 AM   #6 (permalink)
dchoate2's Avatar
Same here man appreciate it
Old 10-26-2011, 01:00 PM   #7 (permalink)
Banned
Confirmed Fix
1. No overdrive and has a code 45 for governor pressure....
1997 Dodge Ram 2500 5.9L, DIESEL, Vin D, Turbo, Eng Cfg L6 *
Test Details... Confirmed Fix Details...
Tests/Procedures: 1. Check for a 5 volt feed at the Orange wire at the transmission solenoid wiring. 2. Check for approximately 0.6 to 0.7 volts at the Powertrain Control Module (PCM) connector C2 pin B29 with th...
1 Confirmed fix Powertrain Control Module (PCM)
Solenoid
Wiring
1 - Transmission Valve Body
lucky1 is offline   Reply With Quote
Old 10-26-2011, 01:04 PM   #8 (permalink)
Banned
Description Potential Causes Confirmed Fix
1. Transmission has no overdrive engagement....
1995 Dodge Ram 3500 5.9L, DIESEL, Vin C, Turbo, Eng Cfg L6 *
Tests/Procedures: 1. Check for voltage at the solenoid connector. Check the wire between the Powertrain Control Module (PCM) and the OD solenoid. Do an actuator test with a scan tool and connect a DVOM to the Brown wi...
1 Confirmed fix Overdrive Solenoid
Sensor Input
1 - Overdrive Unit, Overdrive/Lock-Up Solenoid Pack
2. The transmission is not shifting into overdrive. Code P1693 is present....
1998 Dodge Ram 3500 Quad Cab 5.9L, DIESEL, Vin 6, Turbo, Eng Cfg L6 *
Tests/Procedures: 1. Check the codes in all available modules, this code means there is a fault code present in another module such as the Electronic Control Module (ECM). There is an ECM and a Powertrain Control Modu...
1 Confirmed fix Fault Code
1 - Powertrain Control Module (PCM)
3. No overdrive. Scan tool shows the Powertrain Control Module (PCM) is commending the solenoid on. Have power to the solenoid, tried grounding the solenoid manually and still do not get overdrive. No c...
Test Details...
Tests/Procedures: 1. The solenoid assembly has failed or there is an internal hydraulic problem inside the transmission.... Solenoid Solenoid assembly.
Transmission Mechanical Problem
Old 10-26-2011, 08:03 PM   #9 (permalink)
i would hate to say if that didnt help me but i dont quite understand it when they all end in the middle of the pocedure. my tps is banged up pretty bad so im thinking of getting a new one...little little plastic back fell off and the insides came out i tried to put it back together but im not sure how well i did
Old 10-26-2011, 08:30 PM   #10 (permalink)
have you tried the output speed sensor on the overdrive unit i herd that helped some people that will be my next try after tps
Old 10-28-2011, 08:00 PM   #11 (permalink)
95cummins4x4's Avatar
how much did you pay for your tps?
95cummins4x4 is offline   Reply With Quote
Old 10-28-2011, 08:09 PM   #12 (permalink)
Super Moderator
I paid $148 at Napa last spring.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
The Following User Says Thank You to illflem For This Useful Post:
95cummins4x4 (10-28-2011)
