mystery switch problem on my '95 - Dodge Cummins Diesel Forum
Old 10-25-2011, 03:17 PM   #1 (permalink)
Kent Earnest's Avatar
wired up my mystery switch today on the '95 in my sig and it doesn't really work because the TC still cycles lock/unclock
Tapped PIN 54 at the PCM and grounded the switch under the dash. I used a simple on/off rocker switch with LED but didn't hook up the LED. When the TC unlocks the LED comes on.
Is the LED the problem? Should I just get a simple on/off toggle switch?
Thanks,
'98 24V 2500 4x4 5sp PDR40, TST ECM, DD2's, 128K miles
'95 12V 2500 4x4 Auto 246K miles, Stock power for now...
Kent Earnest is offline   Reply With Quote
Old 10-25-2011, 04:54 PM   #2 (permalink)
brandonabee's Avatar
You prob hooked to the wrong prong on your switch?
97 2500 12v auto,transgo shift kit n10 fuel plate forward, brass power fitting,with AFC tune, fuel gauge,bhaf,kdp tabbed ,fuel heater delete, boost,egt,trans temp gauges , tork Tek ofv, 4 inch exhaust, tow mirrors ,HIDs,steering box brace leveling kit on 35s- turd
brandonabee is offline   Reply With Quote
Old 10-25-2011, 06:46 PM   #3 (permalink)
illflem, any ideas on this one
Old 10-25-2011, 06:58 PM   #4 (permalink)
to be shure you never in the prosess connected anything to positeve current?
Ram 2500 12v 5.9 cummins turbo, 47RH Auto. all stock. exhaust, transmission and boost gauges. home made manual lock up controlers fuel plate a bit frw. starwheel detuned.. 38" superswampers custom fender extensions.
articfarmram is offline   Reply With Quote
Old 10-25-2011, 07:47 PM   #5 (permalink)
Super Moderator
Switch lighting can cause problems but only if you have positive battery power connected to the switch.
My bet is a bad ground.
It's may not be your ground to your switch but rather the ground that supplies the place where you connected.
Did that make sense?
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
Old 10-26-2011, 09:40 AM   #6 (permalink)
that makes sense. I'll check my ground today.
Old 10-26-2011, 02:12 PM   #7 (permalink)
Het Bill,
my ground was good, turned out it was the LED switch. I replaced it with a simple on/off toggle and it works great
I should have done this 3 years ago when I got the truck
Thanks,
Kent
