quick valve spring ? - Dodge Cummins Diesel Forum
Old 10-19-2011, 03:46 PM   #1 (permalink)
lowbudgelifestyle's Avatar
installing valvesprings right now on a friends truck, if #1 int and exh lash is loose does that indicate tdc? because only one rocker lash is loose on #6 right now. could that just be the valve lash is off?
copper cashcrop
lowbudgelifestyle is offline   Reply With Quote
Old 10-19-2011, 03:57 PM   #2 (permalink)
zthatzmanz28's Avatar
See if this helps..
Top Dead Center!
1998 2500 4X4 CTD QCLB 3 inch lift-- Stablizer Bar-Tork Tek OFV-MAXX links-KDP TABBED-Luke's Link & Bushing POTS LMC dash #10 fuel plate AFC ISSPRO fuel- boost-2K* PYRO BHAF Larry B Solenoid & relay rebult 47re low stall TC
zthatzmanz28 is offline   Reply With Quote
Old 10-20-2011, 06:53 AM   #3 (permalink)
Thanks, I ended up figuring it out i was just 2nd guessing the method I used, but now after gov springs, valve springs, and resetting the valves, and a trans temp gauge, the abs and parking brake light is on..?
could it be the small, plastic vaccume lines that come from the cowl? They were dry as heck and cracked, but I thought they were for the a/c
copper cashcrop
