will a fuel and pump tuning ruin my fuel milage ? - Dodge Cummins Diesel Forum
post #1 of 26 (permalink) Old 10-11-2011, 11:01 PM Thread Starter
dvs97250012v's Avatar
Exclamation will a fuel plate and pump tuning ruin my fuel milage ?
Rite now my motor is all stock with the exception of a cold air and a 3" strait pipe and if i dpnt drive it lile a race car i get just over 20 mpg, so if i do a lightly modded fuel plate (not sure what number plate i would even nees) and pump tuning would my city milage go down?
972500sclb4x412valvestock47reautometerHX35#11plateboost elbowpusherAEM CAI tork tec ofv285 kelly safari tsr'ssilencer ring MIA4" strait pipe 6" tipderale deep trans panonboard air w/grover 15108'hiniker c-plow
dvs97250012v is offline
post #2 of 26 (permalink) Old 10-11-2011, 11:16 PM
VP of the dry side
cumminsrulez's Avatar
umm my milage actually went up a couple miles per gallon. it may be one or two miles but hey any bit helps and u will like the gains. if u can keep ur foot out of it lol. but i also got a 5 speed so idk if that changes anything. the fuel plate is also a good mode. id just move my stock plate forward. but idk if i would move it fully forward. depends on how your trans is doin and what u will be doin with it
97,2wd, auto swapped, Moss Green, 211k, s&b,4in with muffler stock tip
(stealth mode engaged
) ,afc mods, kdp,egt boost fp dp,22*,Haisley 5k gsk-60pounders,traction bars, A1 studs+Oring'd block, P&P, A1000 custom fuel setup,5x.018 SAC 145* 300 bar,.025 dvs, 64.5/68/.83 t4 sxe 50mm jgs gate/w screamer pipe
Originally Posted by dvst8r View Post
Dying is always a way bigger concern than egt's...
cumminsrulez is offline
post #3 of 26 (permalink) Old 10-11-2011, 11:22 PM Thread Starter
Well ive read that removing and or moving the stock plate forward it will increase my egts and with a loaded trailer i can stannd on ot comming off of an onramp or going up a hill i moght hit 950 deg on the pyro so i dont wanna kill my egts it why im considering a plate rather than moving the stock one
post #4 of 26 (permalink) Old 10-11-2011, 11:37 PM
1,200-1,300 EGT's for a few seconds wont hurt it.
Maxed 12mm pump, nv4500 w/ Valair DD, 35'' BFG on 3rd Gens, S300 Borg Warner, 12mm ARPs, BHAF, A-Pillar gauges and bad case of ITS
DC9612V is offline
post #5 of 26 (permalink) Old 10-11-2011, 11:44 PM
ykdave's Avatar
you can hold 1250* (pre turbo) all day long, you can go higher for a short amount of time without worry, but the higher you go the shorter you can hold it there!
ykdave is offline
post #6 of 26 (permalink) Old 10-11-2011, 11:45 PM
According to cummins, 1250 degrees (pre turbo) for 50 billion years won't hurt it. That's the max safe continuous temp.
'98 12v 2wd dually, SB DD, Detroit locker, 64/65/13 htb2, CPP 7x10's, 3kgsk, bhaf, 19*, 50 lbs boost
v8440 is offline
The Following User Says Thank You to v8440 For This Useful Post:
dvs97250012v (10-12-2011)
post #7 of 26 (permalink) Old 10-11-2011, 11:47 PM Thread Starter
Yeah i know if its for a short time it will be fine but why risk my exha temperature going up when a new plate with new bolts and a boost fitting is under $30 on e bay
post #8 of 26 (permalink) Old 10-11-2011, 11:48 PM
Run a pre-post EGT gauge....like me haha. Truck is like a spaceship...lots of gauges, Its awesome.
DC9612V is offline
post #9 of 26 (permalink) Old 10-11-2011, 11:49 PM Thread Starter
To v8440 thats very good to know what cummins opinion is, thanks
post #10 of 26 (permalink) Old 10-12-2011, 07:15 AM
A #10 plate is towing friendly, moving the stock plate as you mentioned is not. It will take some moving it around to get it where you want it to keep EGT's in check. I personally try to keep my temps below 1200* and for a long pull up a hill I even try for 1150*. A five mile pull up a hill is enough to do damage if temps go too high. I know gauge manufacturers tell you their gauges are extremely accurate, but if it is off just 50* to 75*, that's enough to make a huge difference in five miles. Another key to EGT's is to bump the timing up to 15.5 or so degrees.
RPegram is offline
The Following User Says Thank You to RPegram For This Useful Post:
post #11 of 26 (permalink) Old 10-12-2011, 09:42 AM Thread Starter
So you are saying that even if I buy a numbered plate I still have to play around with it and adjust it do find the so called sweet spot ? It not just a bolt in mod?
post #12 of 26 (permalink) Old 10-12-2011, 09:50 AM
With a #10 plate you may could go full forward and be ok. Before buying the plate, take care of trans.
RPegram is offline
