New Throttle Cable??? - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 09-07-2011, 08:14 PM Thread Starter
automotiveadam's Avatar
So I was driving and all of a sudden my foot went to the floor. No throttle. I had to idle home (thankfully I was only a half mile away). Sure enough the clip that holds the cable to the throttle body is worn out. I went to napa, they don't have it, and I searched online also no luck. So have any of you guys had experience with this or do you know where I might be able to find one?
Thanks in advance
Adam
Adam-
1996 dodge ram 2500 CCLB, 4x4, laramie, automatic
4'' exhaust, KDP Tabbed, silencer ring MIA, fuel heater delete, 4.10s
automotiveadam is offline
post #2 of 8 (permalink) Old 09-07-2011, 08:49 PM
It's covered under a recall for free.
Check if it's been done with your VIN here> Dodge - Contact Us
Even if it's been done and broke again it's still covered for the life of the truck.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #3 of 8 (permalink) Old 09-07-2011, 09:33 PM
alpha33's Avatar
I zip tied mine and it has been operating good for a few months like so, but I think I will take it to get properly fixed.
05 Laramie | hardened 12v rods | 03-04 pistons | 12mm main studs | Haisley P&P head | 625 head studs | EDuty pushrods | Coolant bypass |150% exergy injectors | PPE Dual CP3 | s464/83/90 over s480/96/1.32 | HTT T4 Mani| Billet Trans | AD 150
alpha33 is offline
post #4 of 8 (permalink) Old 09-07-2011, 10:12 PM Thread Starter
thanks for the response. I went on dodge plugged in my vin number, and it said there was no recalls. I sent them an email anyway, but is this a problem for the 94s and 95s only?
Adam-
post #5 of 8 (permalink) Old 09-08-2011, 05:02 PM Thread Starter
Well I called dodge and they said since it's been 10 years since the recalled part has been replaced, that its void. So then I called a dealer and the cable was $79!!!
So I might just fiberglass it. If i can't fight the recall void
Adam-
post #6 of 8 (permalink) Old 09-08-2011, 05:47 PM
GAmes's Avatar
iTrader Score: 7 reviews
Order kit part #CANZ9700. It will include a throttle cable and several small parts you might also need. Should be around $16
97 3500, 2 WD, G56, slightly bombed, 1.2 million miles. Started the second million on 8/24/13
GAmes is offline
post #7 of 8 (permalink) Old 09-08-2011, 08:35 PM Thread Starter
Ok that sounds much better. Where do I order that from?
Adam-
post #8 of 8 (permalink) Old 09-08-2011, 09:01 PM
Dodge deaLer
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
