Fifth Gear Lock Nut Retainer - Dodge Cummins Diesel Forum
post #1 of 41 (permalink) Old 06-22-2011, 10:00 AM Thread Starter
Has anyone had any experience with this 5th gear nut fix? I have replaced the nut 3 times and dont want to spend $700 on the main shaft...This thing is $145: NV4500 Transmission 5th Gear Repair
1998 QCLB 12v 2500 4x4 5spd
Scotty II intake, 304 stainless 4" TBE, #10 plate FF, Isspro boost & EGT guages, 43psi
Rowingfish87 is offline
post #2 of 41 (permalink) Old 06-22-2011, 11:13 AM
I don't have any experience with the 5th gear nut, but I did notice that the very first sentence on the website is a run on.
94 2500 rclb 5spd 2wd, 5x.016, 14.5 4k GSK, 60 lb springs, 13125-OFEK
thecheese429 is offline
The Following 2 Users Say Thank You to thecheese429 For This Useful Post:
keaton_fountain (02-06-2014), nuljas23 (07-26-2013)
post #3 of 41 (permalink) Old 06-22-2011, 11:15 AM
CAPTAIN DILLIGAF
BEERPLAY's Avatar
ON MY 96 I ENDED UP PUTTING A LOCKING NUT ON IT HAD 3 SET SCREWS AND IT HELD GREAT
BEERPLAY is offline
post #4 of 41 (permalink) Old 06-22-2011, 12:00 PM Thread Starter
I was looking for actual experience, I talked to the owner of the company for 20 minutes and he seemed like a stand up guy. Just want some personal experience.
I'm not talking about the updated 5th gear nut, did you click on the link? I have already had 3 of the "updated" nuts back off. This seems like a fairly simple, cost-effective solution.
post #5 of 41 (permalink) Old 06-23-2011, 11:24 PM Thread Starter
bump.......
post #6 of 41 (permalink) Old 06-23-2011, 11:52 PM
Rescue Tower
Shainer's Avatar
What's the definition of insanity... something about doing the same thing over and over expecting a different result? I have yet to see any place recommend replacement of the 5th gear on a worn shaft. You've now allowed four sets of gears to work on that same shaft and you're considering going for number 5. I think it's a bad idea, but its your cash, and this is the internet.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #7 of 41 (permalink) Old 06-24-2011, 12:50 AM
When i bought my truck the guy i got it from said he rebuilt the tranny. well 500 miles later 5th gear nut backed off. i talked to a guy and he said he just tack welded the nut on perfectly diagonally in two spots. so i did it works great just when you do it make sure the welds are the same size so that the shaft does not get thrown out of balance it works great now.
96 12 v 3500 5 speed cab and chassis 11ft flat bed gn and dmi hitches k&n stock air filter
redneckfarmer is offline
post #8 of 41 (permalink) Old 06-24-2011, 08:14 PM
I've welded alot of them lol just hope you dont have to take it off!
97 12v nv4500 4x4 sb clutch #10 plate HTTurb lot mo
96 12v nv4500 4x4 all stock-for sale
92 nv4500 p pumped 4x4-in progress
Mr.dudemanbro is offline
post #9 of 41 (permalink) Old 06-24-2011, 10:16 PM
smokin247's Avatar
I have the retainer in my trans now but only 1000 miles so far if it fails I'll be sure to post it up but I don't think I'll be having any problems with it.
97 nv4500 4x4. 63/68/.83, 5x14, 025dv, airdog 200gph, Hellman sump, steedspeed T4, Hamilton 188/220, Hamilton HD pushrods, SDX beehive springs & retainers, valair 3800 DD.
^now building a new engine.
smokin247 is offline
The Following User Says Thank You to smokin247 For This Useful Post:
Rowingfish87 (06-27-2011)
post #10 of 41 (permalink) Old 06-25-2011, 12:31 AM
brickwahl681's Avatar
Weld it, They even did this on the TV show Trucks when they built the ford on a Dodge chassis with a 5.9 and a 5 speed.
95 dodge 12 valve 3500 4x4 duelly with a automatic
Didn't you know stickers are worth 30hp
brickwahl681 is offline
post #11 of 41 (permalink) Old 06-25-2011, 12:45 AM
That is actually the fix that most of the trans. shops do to fix the problem, they weld the gear on both sides evenly, it doesnt come loose again, I have personally seen this done many times.
98.5 Auto 1-ton no mods
horsefly is offline
post #12 of 41 (permalink) Old 06-27-2011, 11:34 AM Thread Starter
I talked to the owner of active gear (company that makes the retainer) and he said he hasn't had a single failure of the retainer in the 2.5 years they have been making it.
I'm gonna order mine today and I will post up when I get it installed.
The Following User Says Thank You to Rowingfish87 For This Useful Post:
Cummins 24 (02-08-2012)
