What year did Dodge come out with computer controlled engines? - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 06-08-2011, 01:19 AM Thread Starter
Hello,
I don't want computer controls in a diesel motor, a personal preference, I am wondering what year did Dodge start with the computer controlled motors (Injectors, timing, anything).
tundrawolf is offline
post #2 of 8 (permalink) Old 06-08-2011, 01:28 AM
1998.5 and up are computer controlled and 24 valve motors.
your looking at the 12v... 1989 (I believe) to 1998 (early) which will have either a VE rotary pump or P7100 (pPump).
the only electronic part on the 12v for it to run is the shut down solenoid
Obsessed with power is such an understatement!
The pursuit of power is more often than not an unobtainable goal that is remedied by DEATH
FIRESTARTER is offline
post #3 of 8 (permalink) Old 06-08-2011, 08:15 PM Thread Starter
Thank you very much, that was an excellent reply.
post #4 of 8 (permalink) Old 06-08-2011, 11:59 PM
txsmoker's Avatar
read the newbie threads lots of info for new guys and experts alike
96 2500 12v 4x4 Reg. cab silver
100 plate, 5" diamond eye, S&B, ISSPRO gauges, 4k GSK, BD boost tubes, TransGo, Precision Triple Disk TC, Billet input, Hamilton 188/220, 191 DV, II Silver 64
txsmoker is offline
post #5 of 8 (permalink) Old 06-09-2011, 07:37 AM
1991. Computer for tach.
1994. Computer for cruise and alternator.
1998.5 Computer for injection pump.
08 5500 4x4 G56 4.44s, SB 3250 dual disc, XRT... Spicer 7041 Aux trans.
95 2500 4x4 G56 180 pump, injectors, 362/475 twins and more....
burnin oil is offline
post #6 of 8 (permalink) Old 06-09-2011, 03:05 PM
on my buds 1st gen, the computer also controls the regulator/rectifier... 93 w250 12v
his computer went out, so he has to manually turn on his gauges and reg/rect and if he leaves the switches on after he shuts off the truck, they kill the battery quick.
also, his doesn't have a stock tach... aftermarket one off the alt, but no factory tach
post #7 of 8 (permalink) Old 06-10-2011, 12:34 AM
the pcm on the 2nd gen 12 valve controls alot more then u think... charging, cruise, all tranny controls other then 1,2,3 gears, fuel shutdown, from my experience the mighty 12 valve is harnessed by dodge junk way more then it should,get a 5 speed and save ur self alot of time and money, im at almost 300 bucks in testing and useless parts and the pcm still has to be bypassed to get it to charge and go into o/d and l/u
95 auto 200k stock.......for now
viper 1987 is offline
post #8 of 8 (permalink) Old 06-10-2011, 02:23 PM
you don't need the electronic shut down solenoid, you can have it cable operated if you'd like. there is no need for a battery when a 12v is running, unless you want a radio or something. haha
