Truck wont go into gear - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 05-05-2011, 08:48 AM Thread Starter
Fine 5.9's Avatar
I bought a 96 cummins 5 speed 3 days ago and now when i start it up in neutral and try 2 put it into gear it wont go. I have 2 shut the truck off and start it in gear and when it starts it wants 2 pull. When u push in the clutch it it still pulls a lil. I put a new clutch master cylinder and slave cylinder on it and bleed all the air out of the line.. still have the same problem. The truck used to be a auto and it got converted into a 5 speed NV4500. The guy i bought it off of said it uses the slave and clutch master out of a 98 truck. It is very hard 2 get into gear after your moving and it don't want 2 down shift easy at all. Any ideas on what it could be??? Thanks for your time!
2007.5 6.7/4x4/EFI Fleece/fire punk comp 2 48re swap/625/o-ring head/stainless diesel 2nd gen manifold/fleece S468/65% S&S injectors/ATS Dual cp3s/pusher intake/3.5 boost tube/Hamilton HDpush rods/103lb valve springs/bored .020 over/mahle pistons/fass 150
Fine 5.9 is offline
post #2 of 5 (permalink) Old 05-05-2011, 12:47 PM
either the clutch or pressure plate have failed. maybe both. make sure everything is together correctly and the slave and master cylinder are working correctly, and if everything is...then it's time for a new clutch. good luck and let us know what you find.
rande
1996 2500 clb cab long bed auto, stock airbox with stock filter, no fuel plate, tranny holding fine. Recon L E D taillights an 3rd brake light. isspro gauges, boost, pyro, trans temp, AND MBRP 4inch exhaust, no tip.
randemelissa is offline
post #3 of 5 (permalink) Old 05-05-2011, 05:55 PM Thread Starter
Fine 5.9's Avatar
ok Thanks. I'm gonna take the trans out and see whats goin on.
Fine 5.9 is offline
post #4 of 5 (permalink) Old 05-05-2011, 07:44 PM
let us know how it goes for you and good luck.
rande
post #5 of 5 (permalink) Old 05-15-2011, 01:16 PM Thread Starter
Fine 5.9's Avatar
I took the trany out and the clutch blew apart. Most of the springs were falling out and the whole thing came apart when i got it out. I put a single disk Ceramic/Kevlar clutch in it from Valair Clutch Inc. and That fixed the prob. Thanks for the help!
Fine 5.9 is offline
The Following User Says Thank You to Fine 5.9 For This Useful Post:
Valair1 (05-15-2011)
