Draining water from fuel filter - Page 2 - Dodge Cummins Diesel Forum
post #13 of 21 (permalink) Old 11-22-2011, 10:06 PM
My water in fuel lights on now to, but it's after I washed it. I've for a flat bed on it so the cap is exposed...should I just drain the fuel filter and see if the light goes off?
13' Denali HD - AFE 5in, S&B, H&S(Kory Willis), MA, AirDog, DRP, HSP, Edge
12' Ram 3500 C&C - H&S, Flo~Pro 5in, S&B, GDP, MBRP, Shibby Eng
DirtyMaxDiesel is offline
post #14 of 21 (permalink) Old 11-22-2011, 10:43 PM
Bump......
post #15 of 21 (permalink) Old 11-23-2011, 12:16 AM
rideordie1113's Avatar
That's a common thing. Just let it go and it'll be fine. Water getting in the sensor (from washing it) will throw it on too. Completely fine. Might as well try letting a bit out, but it's likely just got to dry out.
1994 Ram 2500, 5 speed, 4x4 - 370 injectors, head studs, Valair ceramic DD
rideordie1113 is offline
post #16 of 21 (permalink) Old 11-23-2011, 01:46 AM
So the water isn't going to turn to steam and blow my injectors apart?
post #17 of 21 (permalink) Old 11-23-2011, 05:37 AM
Nope, either just drive it until the light turns off or take the connector loose, clean well with WD-40 (WD stands for Water Dispersant), blow it out with compressed air, slap it back together and then drive it.
RPegram is offline
post #18 of 21 (permalink) Old 11-23-2011, 09:30 AM
cumminsbeliever's Avatar
yup !!! happens to me now and again. I drain a bit of fuel to be sure, then clean the plug with some electric parts cleaner or even throttle body or brake cleaner spray. A good shot of compressed air and Bob is you fathers brother.
2001 Ram 3500,6 speed dually,edge juice with attitude cts/4 inch exhaust,cool air intake, rv 275 injectors.
cumminsbeliever is offline
post #19 of 21 (permalink) Old 11-23-2011, 11:15 AM
cjensen91910's Avatar
If you fill the plug in with dielectric grease, then put it together water has a hard time getting in, unless you pressure wash. NAPA Gold 3395 (Wix), is a good number for a no drain filter.
95 Auto, billet TC and modded valve plate, BHAF, Aux lift pump, three position lockup switch, full gauges, #5 plate, no muffler and CAT is gutless. Timed at 15.5, full EGR brake package.
cjensen91910 is offline
post #20 of 21 (permalink) Old 11-23-2011, 11:26 AM
But what happens when water really gets in the fuel system...it doesn't hurt the injectors? This is an 09 6.7...I think the water in fuel is a bigger deal when your dealing with 26,000 psi at the fuel rail.
post #21 of 21 (permalink) Old 11-23-2011, 12:05 PM
I'm pretty sure everybody assumed you were referring to a 12 valve. You posted in the 94-98 section. If it's a 6.7 I would probably try draining it out at least, but the same rules probably apply I'd imagine.
