Problems with my 96 - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 04-01-2011, 06:47 AM Thread Starter
Problems with my 96
Im new to this site, maybe someone can help me? I have a 96 dodge cummins with 286k on it. It's been a wonderful truck with minimal problems. Seems the turbo has stopped working or its starving for fuel? It always starts up just fine but, rev engine to anything over 2000 rpm, it starts choking missing and really smokes out exaust. When I'm driving it I must really feather the pedal or it just chokes. As long as I stay around 1800 rpm there is no problem but, when I start up a hill doing 65 mph it just wont go. Anyone have any suggestions? I thought it might be the lift pump? Thanks very much, Charlie..
cgraves5653 is offline
post #2 of 10 (permalink) Old 04-01-2011, 08:17 AM
start by checking your air filter. do yourself a favor and read all the sticky posts and then do a search. good luck to you. let us know what you find.
rande
1996 2500 clb cab long bed auto, stock airbox with stock filter, no fuel plate, tranny holding fine. Recon L E D taillights an 3rd brake light. isspro gauges, boost, pyro, trans temp, AND MBRP 4inch exhaust, no tip.
randemelissa is offline
post #3 of 10 (permalink) Old 04-01-2011, 07:16 PM
Sounds like low fuel pressure> http://www.cumminsforum.com/forum/94...-12-valve.html
If you've never replaced the overflow valve do so> http://www.fostertruck.com/Overflow_valve.htm
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #4 of 10 (permalink) Old 04-02-2011, 02:27 PM
kfisher's Avatar
timing? air filter? low fuel pressure? fill out a sig for us some kind of intake and a straight pipe could help.
97 EC, LB white, smoked cab lights, 4 inch skyjacker firestone bags and 37s on 17s. afc tuned, #0 slid where it needs to be, boost elbow @ 37lb, BHAF, 4 inch straight pipe to 6inch single stack, 100hp injectors, gauges (boost/egt) valair single 450hp 850lb ft
kfisher is offline
post #5 of 10 (permalink) Old 04-04-2011, 09:00 PM
Babyfat's Avatar
Fuel filter?
2000 WHITE 3500 DRW,SPORT,4X4, EDGE COMP,TST PM3, FUELBOSS, DTT, 6" STACKS, Mach 6's, HX40/HT4C
2004.5 SWB 2500 SHOP TRUCK
2002 3500 drw 6sp
Babyfat is offline
The Following User Says Thank You to Babyfat For This Useful Post:
cgraves5653 (11-01-2011)
post #6 of 10 (permalink) Old 11-01-2011, 07:49 PM Thread Starter
rande
sorry so long getting back Rand - like i said new to the site but " This site is Awesome!! I put in a new air filter and fuel filter and it purred again !! thanks again for your help!
post #7 of 10 (permalink) Old 11-01-2011, 07:51 PM Thread Starter
Was fuel filter and air filter. thanks everyone..
post #8 of 10 (permalink) Old 11-01-2011, 08:04 PM
deezall's Avatar
what color smoke?? do you hear the turbo spooling??
96 extclb12v 4x4 bags of goodies
2011 ram 3500 bone stock the paw paw yeti
deezall is offline
post #9 of 10 (permalink) Old 11-02-2011, 05:20 PM Thread Starter
white - started coughing before turbo would spool
Thanks, Charlie.. 96 dodge cummins stock-308k
post #10 of 10 (permalink) Old 11-03-2011, 02:32 AM
deezall's Avatar
good to here you fixed it
deezall is offline
