Driving with a converter that will not lock up - Dodge Cummins Diesel Forum
Old 03-31-2011, 05:20 PM   #1 (permalink)
mopar01's Avatar
hey all, i know for a fact after alot of testing that my converter is bad, well it has no lockup as in the lock up lining went, can i still drive the truck with it out of overdrive? or will i do more damage? im trying to buy a new coverter an a rebuilt trans so its all fresh and new... but the cash hasnt come to me yet. let me know what you think
2002 Dodge 3500 4X4 cab chassis 24 valve automatic, flat bed/dump bed, full guages, smarty S-03, BHAF, MBRP 304 cool duals.... 1995 Dodge 2500 4X4 long bed 12 valve automatic stock fuel plate slid foward, AFC slid foward 4" custom exhaust KDP tabbed::
mopar01 is offline   Reply With Quote
Old 03-31-2011, 05:38 PM   #2 (permalink)
I've been driving my truck for a year anda half with a half working lock-up clutch... drops like 100 rpm when it "tries" to lock-up. Doesn't burn the fluid and is still shifting just fine. Is it painful to drive without lock-up YES, have I been doing it for a year and half yes. But if I could afford it it would be totally rebuilt.
98 12V auto 3.55 213K+miles, BHAF, Full 4" exhaust,AFC tuned just right.boost/pyro, 7 Blade HX35, 5x.012 Con. injectors,48RE trans with suncoast tripple disk TC koleene steels and trans-go shift kit, Tork Tec Adj. OFV
98-6BTA is offline   Reply With Quote
Old 03-31-2011, 11:35 PM   #3 (permalink)
Art
I wouldn't drive it that way.
The failed lining can flake off and lodge in a cooler and restrict flow. Or it could continue through and block a lube orifice in the trans.
Fix it properly now, or fix more later. Its your call.
WANTED: 1930 Dodge DD parts
lets go vintage drag racing: www.meltdowndrags.com
Art is offline   Reply With Quote
Old 04-05-2011, 03:38 PM   #4 (permalink)
A non locked up TC is not letting the trans cool as it should. I'd get it fixed ASAP.
Non locked up, it doesn't let fluid flow. You're slowly burning up your trans
the_husk is offline   Reply With Quote
Old 04-05-2011, 06:12 PM   #5 (permalink)
well heck, just lock it out of od and see if that helps. good luck.
rande
1996 2500 clb cab long bed auto, stock airbox with stock filter, no fuel plate, tranny holding fine. Recon L E D taillights an 3rd brake light. isspro gauges, boost, pyro, trans temp, AND MBRP 4inch exhaust, no tip.
randemelissa is offline   Reply With Quote
Old 04-06-2011, 11:07 AM   #6 (permalink)
Lock up and OD are two different things. Lockup will happen in 3rd if OD is off (OD light on). If you force lockup to stay off you can drive it in OD with no problems. As Art said above it is not a good idea.
KDP tab fix info and fuel system article jgeorge1@suddenlink.net '95 2500 CC auto 4X4, 3.54, EGT, boost, fuel pressure, trans temp guages, PacBrake, TST #5, DTT VB, DTT triple disk TC, DTT billet flex plate, Cummins chrome kit.
Joe G. is offline   Reply With Quote
The Following User Says Thank You to Joe G. For This Useful Post:
randemelissa (04-08-2011)
Old 04-08-2011, 09:52 AM   #7 (permalink)
i apologize. i learned that just yesterday towing a car. i appreciate you explaining that to me. have a good day and good luck to the op.
rande
