please help kdp quick question - Dodge Cummins Diesel Forum
Old 03-28-2011, 08:34 PM   #1 (permalink)
greggsxr1000's Avatar
The kdp got my truck. So I was fixing the problem and when it came time to remove the cam. The cam was stuck when pulling it the first few inches. So I really gave it a good yank and heard something drop. pretty sure it was in the motor. Maybe I bumped a socket off the truck? Not sure. I checked all the tappets were still there. All the bearings still looked like they were there.
I rotated the crank a couple turns maybe if it was on the connecting rod it would drop into the pan. Nothing. Maybe it fell to the pan in the first place. nothing. Am I just being paranoid? Also when the cam was stuck I could spin it 359 degrees in either direction and it would stop. And tried to turn more it would spill fuel?
98 12v 4X4 NV4500 35's bhaf 4"dp straight piped 3kgsk #0 plate gutted afc
greggsxr1000 is offline   Reply With Quote
Old 03-28-2011, 09:14 PM   #2 (permalink)
did one of your tappets fall out? Did you use dowel rods to hold them up and from not falling out.
Daily Driver: 2004 Ram 2500 Quad Cab 4x4 Long Bed Automatic 5.9l CTD 23k miles and counting, 4" MBRP Turbo Back exhaust
abe568 is offline   Reply With Quote
Old 03-28-2011, 09:25 PM   #3 (permalink)
moparguy55's Avatar
iTrader Score: -1 reviews
There is a metal pin in the lift pump that rides on the cam lobe. The up/down motion from moving on the cam is what makes the pump work. When you pulled the cam the pin fell down into the pan. With the pin gone in the pan that is why your getting fuel. Get a magnet and go fishing in the oil pan. You will have to take the lift pump off to reinstall.
01 2500 QCSB 4x4 6 speed stock,99 QCLB 4x4 auto
91 mustang LX Coupe HCI
70 charger R/T(in restoration)
moparguy55 is offline   Reply With Quote
The Following User Says Thank You to moparguy55 For This Useful Post:
Hit.It. (03-28-2011)
Old 03-29-2011, 08:03 PM   #4 (permalink)
Super Moderator
You're supposed to remove the lift pump before pulling the cam.
Forcing it out ruins the lift pump.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
Old 03-29-2011, 08:08 PM   #5 (permalink)
Bluegrass Diesel
Bluegrass Diesel's Avatar
X2.
Did you get the cam all the way out? With the front cover off of the front of the truck, you should be able to see back into the oil pan some. Its possible that if something fell that you could see back there and fish it out with a magnet. However, the oil pickup tube will make it difficult. I would remove the lift pump and make sure the plunger is still in there and not broken. If you think something fell into the oil pan, I would be awful leary of starting the engine, or turning it over much for that matter.
AFE - ARP - S&B - H&S Performance - Smarty Power - Industrial Injection - BD Diesel - Hamilton Cams - Edge Products - FloPro - Goerend Transmission - South Bend Clutch - Kenny's Pulling Parts - Haisley Machine - Scheid Diesel - Southern Diesel Xtreme - ATS - Suncoast - B&W Hitches - Autometer - ISSPRO - and many more!
www.BluegrassDieselPerformance.com
sales@bluegrassdieselperformance.com
859.792.6994
Ask about a free T-Shirt with your first purchase over $100!
Bluegrass Diesel is offline   Reply With Quote
