boost leak? - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 03-27-2011, 07:27 PM Thread Starter
NJ4life131's Avatar
boost leak?
So over the past week ive noticed my truck has lost a significant amount of power. I talked to one of my buddies and he said it was a possible boost leak? I checked my boots and couldn't see any loose clamps or obvious rips. My trucks egts have been about 300 degrees hotter than normal and the turbo sounds like its screaming even though im only making 5 - 10 lbs of boost. The truck has also significantly decreased in the amount of smoke its producing at WOT. I checked the turbo and there is absolutely no play. I need help and could use any suggestions.
96' 2500 12 valve 4x4 RCLB. starwheel ff, custom #0 plate, 4 inch exhaust, home made intake, trans boost and egt gauges. HTS Ultimate Duty Transmission with Suncoast Triple Disk Torque Converter and billet input shaft
NJ4life131 is offline
post #2 of 11 (permalink) Old 03-27-2011, 07:39 PM
I'm at a loss... maybe it's the intercooler?
I doubt it, as I never hear/read from broken intercoolers in these trucks.
Did you squeeze hard the boots?
A small hole might not be noticeable from the outside.
If you still don't find a problem, I would remove all the boots and check them outside the engine.
My 0.02
Hope you find the problem ASAP!
1st Diesel 1995 Ram 2500 || 5.9CTD || 2wd long bed
Home-made KDP fix || 2x electric fans in front of condenser || tinkered fuel-plate and AFC || boost elbow ||
Hit.It. is offline
post #3 of 11 (permalink) Old 03-27-2011, 09:32 PM
littlerip's Avatar
This might sound dumb but check to make sure your pre boost fuel screw is still in place. I lost mine and while waiting for replacement the truck had about 1/3 the power and almost no smoke. That was due to the boost entering the afc was escaping the hole where the screw shoulda been. Just a thought.
If that isn't your problem use hit it's advice. Let us know what ya find out
:95, 12v, 5spd, 4x4, KDP KILLED!!, air dog 150gph system, 4kgsk, full cut dvs, marine 370 injectors, no fuel plate, 17* timing advance, s300, S&B air intake, dual disc valair
littlerip is offline
post #4 of 11 (permalink) Old 03-27-2011, 10:09 PM Thread Starter
NJ4life131's Avatar
when you say pre boost fuel screw, you mean the cover for adjusting the starwheel on the afc? the allen-type bolt?
post #5 of 11 (permalink) Old 03-27-2011, 10:59 PM
God prefers Diesels's Avatar
No. It's a cover right on the back of the AFC with two flat head bolts. If you take it off, that's the preboost screw. If it fell out you'd have an opening in your induction system basically.
Sounds like a boost leak. I have one right now. Less boost, little more smoke, and higher EGT's. Plus you can hear the whoosh!! instead of the whistle. Just test the system with 10psi shop air or so, and find the leak! You can buy a tester at http://www.siliconeintakes.com/produ...db1fb4c388473b, or make your own!
93 Chevy with '97 215 47rh 241DHD HE351cw/bht3b(26cm) Con7x12tagious
Originally Posted by billow99 View Post
i hate nv 4500s i keep breaking the cluster gear. even with cryo treating. its pointless to expect them to hold up to any abuse.
Originally Posted by randemelissa View Post
You want smoke? throw a rag in your air filter inlet. you want power? we'll help all we can.
God prefers Diesels is offline
post #6 of 11 (permalink) Old 03-28-2011, 08:12 AM Thread Starter
NJ4life131's Avatar
so is there a way to pressurize the system without having to buy that leak tester?
post #7 of 11 (permalink) Old 03-28-2011, 08:45 AM
Yeah, make your own. Basically you just need a way to cap off the other side of the system, and a way to inject air at the beginning of the system. You can just do tubing and intercooler, and you can even hook the tester on your turbo and test through that too just in case you have a leak at the turbo/first tube clamp.
post #8 of 11 (permalink) Old 03-28-2011, 08:46 AM
littlerip's Avatar
Originally Posted by God prefers Diesels View Post
Sounds like a boost leak. I have one right now. Less boost, little more smoke, and higher EGT's. Plus you can hear the whoosh!! instead of the whistle. Just test the system with 10psi shop air or so, and find the leak! You can buy a tester at Intake Pressure Tester, or make your own!
If its a boost leak though, would he not be seeing more smoke like you are. He said in the original post he had significantly less smoke. That makes me think he is not getting all the fuel that he used to.
post #9 of 11 (permalink) Old 03-28-2011, 09:22 AM
With a boost leak limiting boost, he might indeed get less smoke. Remember, the whole purpose of the afc is to limit fuel based on boost. Basically, the afc could cause the smoke symptom to reverse from what you'd expect.
'98 12v 2wd dually, SB DD, Detroit locker, 64/65/13 htb2, CPP 7x10's, 3kgsk, bhaf, 19*, 50 lbs boost
v8440 is offline
The Following User Says Thank You to v8440 For This Useful Post:
God prefers Diesels (03-28-2011)
post #10 of 11 (permalink) Old 03-28-2011, 12:11 PM
That's right!
No boost equals no fuel. In my case, I just have a tear in a boot and still get 45psi which is more than enough for full rack travel. So I still get full fuel, but less boost. If you were just boosting enough for full rack in the first place, and then lost boost, you might be limiting fuel in a case like that. So less smoke.
post #11 of 11 (permalink) Old 05-12-2012, 09:44 AM
I have a 96 12 valve auto with 40+hp injectors, cold air intake, 4" exhaust, banks wastegate and removed the silencer ring. For a few months now I had alot less power, more smoke and really bad fuel milage and I did a pressure test and found my intercooler has a big hole in it, wouldn't hold any air. Should I get this one welded or buy an aftermarket one?
jonc is offline
