twin turbo - Dodge Cummins Diesel Forum
Old 03-18-2011, 02:04 PM   #1 (permalink)
12valvepwer's Avatar
twin turbo
i have a 96 cummins and i am going to buy a BD super B turbo and i am wondering if i can put that turbo on as my primary and make a custom bracket and put the stock turbo as the secondary?
12valvepwer is offline   Reply With Quote
Old 03-18-2011, 07:37 PM   #2 (permalink)
You should use a much larger turbo as the atmosphere charger. A ht3b is an excellent chioce for that combo or a s400. Is your drivetrain able to harness that kind of power? Also your head needs some attention for that kind of boost.
roadwelder is offline   Reply With Quote
Old 03-19-2011, 02:33 PM   #3 (permalink)
Are you saying use them instead of the stock turbo or the super B turbo? And the trans was built to withstand 650 horse but i may be putting a newer six speed into it. Lastly i was going to put injectors in valve springs and governor springs.
Old 03-19-2011, 02:49 PM   #4 (permalink)
If i did use the stock turbo instead of one of them for the secondary would that actually be hurting the power of the super B and giving me less power and torque?
Old 03-19-2011, 09:04 PM   #5 (permalink)
20yearcummins's Avatar
Not to be too critical, but if you aren't sure wouldn't it be better to use a twin turbo set up from one of many manufacturers instead of cobbling something together?
'81 W-350 Cab and Chassis w/'91.5 5.9 Cummins. Soon to have NV5600 NP205 feeding Dana 70 rear and Dana 60 front.
'98 12 valve 2500 4x4 Club Cab Short Box.
20yearcummins is offline   Reply With Quote
Old 03-19-2011, 10:34 PM   #6 (permalink)
95dually3500's Avatar
You can use your stocker and the ht3b or the super b and the ht3b. The super b would be a good replacement for your stock hx35. There are plenty of people running a hx35 - ht3b set up
96 2500 Reg Cab 4x4 - AFE Stage 2 Intake, Pusher intake 4k GSK,ground plate, pump tuned,fass 150 , Autometer-Gauges,Built auto w/Goerand Tripple,Disc
ED BIllet 66/68/.8 & 5x14's SDX Comp DV's 17.5* timing,
95dually3500 is offline   Reply With Quote
