lift pump install - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 03-11-2011, 06:46 PM Thread Starter
lift pump install
so im installing a new lift pump tomorrow any pointers would be appreciated especially when trying to start after its on. thanks
95 cummins, stock automatic w/ shift kit, 5" turbo back, swiss cheese airbox, 3kgsk
twelveV95 is offline
post #2 of 9 (permalink) Old 03-11-2011, 07:16 PM
do a search on it, but it has been recommended that you use studs instead of the trying to get the bolts started. if i can find the size you need i'll post them for you. good luck
rande
1996 2500 clb cab long bed auto, stock airbox with stock filter, no fuel plate, tranny holding fine. Recon L E D taillights an 3rd brake light. isspro gauges, boost, pyro, trans temp, AND MBRP 4inch exhaust, no tip.
randemelissa is offline
post #3 of 9 (permalink) Old 03-11-2011, 07:32 PM
Lift Pump installation tips
Maybe this will help ya a little.
1997 2500 5.9, 3k gsk.
250f4life is offline
post #4 of 9 (permalink) Old 03-11-2011, 08:19 PM
Buy a pair of studs with nuts to replace the stock lift pump bolts and the job will be a hundred times easier.
Size is 8mm x 30mm x 1.25 pitch. Most auto parts carry them.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
The Following User Says Thank You to illflem For This Useful Post:
Hit.It. (04-08-2011)
post #5 of 9 (permalink) Old 03-12-2011, 10:13 AM Thread Starter
the local parts store only has 45mm will that work?
post #6 of 9 (permalink) Old 03-12-2011, 02:23 PM
yes longer the better..thts wht i used
94 2500 green RCLB 5 spd. 20 inch wheels,nitto trail grapplers,hybrid turbo,0 plate,BHAF,pump fully tuned,18.5*timing, mack plug,full cut DV's,ARP's,o-ringed head,188/220 hamilton cam and push rods, 5x.014 injectors pop pressure increased,DD ceramic valair & input
smken u is offline
post #7 of 9 (permalink) Old 03-14-2011, 12:28 PM
Does anyone know if you can replace the rubber boot on the lift pump. On my 94/12v 189000 miles it has split.
Thanks
tucsondon2
tucsondon2 is offline
post #8 of 9 (permalink) Old 03-14-2011, 02:03 PM
Thanks
tucsondon2
The only part that available for the lift pump is the o-ring behind the primer button.
Only way you'll get a new boot is off a used pump.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
post #9 of 9 (permalink) Old 03-14-2011, 08:51 PM
God prefers Diesels's Avatar
Put the top line into the lift pump, and give the nut enough turns so it's started for sure. Then throw it on. Install is a breeze, I thought. But it might be different on a Dodge.
Not to hijack, but after the install, my truck was much quieter. I could hardly hear the engine if I was running the heater. Why is that?
93 Chevy with '97 215 47rh 241DHD HE351cw/bht3b(26cm) Con7x12tagious
Originally Posted by billow99 View Post
i hate nv 4500s i keep breaking the cluster gear. even with cryo treating. its pointless to expect them to hold up to any abuse.
Originally Posted by randemelissa View Post
You want smoke? throw a rag in your air filter inlet. you want power? we'll help all we can.
God prefers Diesels is offline
