blowing antifreeze out
alrite if radiator is full and over flow tank is low with or without the thermostat in, it makes the overflow tank end up over full and blows it out the over flow spout and makes the antifreeze in radiator low, if overflow tank is full and radiator is low it was blowing out around radiator cap, replaced it, if i let both radiator and overflow tank low it dont blow it out, head gasket has been replaced not 10k miles ago, no leaks on the head either, but i also had bolts broke in head from stock exhaust manifold and had a guy drill them out. is it possible he got off just alil and ended up in the water jackets, just a pin hole or is it cause of head gasket again even tho no oil in antifreeze or antifreeze in oil, dont know what temp im running cause the guy broke the stock one and aint had time to get another one, but as far as i can tell its not running hot, and still runs better than it has in a very long time.... whats yalls answer to the antifreeze blowing out.....
1997 Dodge 3500 ext cab flatbed, fuel plate grind on, valair 13" clutch, 5spd rebuilt, custom stacks with custom 4in black bullhaulers, lots of LED Lites, newer towing mirrors, rolling the coal
