Antifreeze Everywhere!!! - Dodge Cummins Diesel Forum
Old 02-25-2011, 02:42 PM   #1 (permalink)
brschriever's Avatar
So i noticed today when i was coming out of sheetz that my truck had antifreeze leaking all over the ground. I drove it home, checked the overflow for cracks, but there was no holes or cracks. I just put on a new water pump on and it is still spraying antifreeze, put a new thermostat in and it is still spraying antifreeze, took the radiator hoses off and they have no holes. I can't tell where the antifreeze is commin from. It seems like it is coming from the upper part of the engine, because when it leaks it gets antifreeze all over the belt, and the belt throws it all over the engine. Please tell me your suggestions of what i should check next.
2003 Reg Cab Auto, Airdog2 165, 4in exhaust, afe intake, decent set of injectors
brschriever is online now   Reply With Quote
Old 02-25-2011, 02:44 PM   #2 (permalink)
did you check your heater hoses?
98' 2500 qc sb billet trans and converter, 5x12 inj., ED 62/68/14, PDI ex man., 4gsk, air dog 150, head studs, s&b intake, Hamilton cam, pushrods, springs, ported head, .24 dv
SUPERDUTY5.9 is online now   Reply With Quote
Old 02-25-2011, 02:46 PM   #3 (permalink)
Is it on the 24v? if so check the block
Old 02-25-2011, 02:56 PM   #4 (permalink)
No its a 12v, and what do you mean by heater hoses
Old 02-25-2011, 03:29 PM   #5 (permalink)
12valveguy's Avatar
heater hoses go to the heater core to produce heat in the cab. When facing the engine from the front they are on the left and they go through the firewall from the block. They are full of antifreeze and could be your issue.
1996 Dodge 4X4, 12V, longbed, club cab. Bone stock (except for a 4" exhaust, and K&N filter).
12valveguy is offline   Reply With Quote
Old 02-25-2011, 03:37 PM   #6 (permalink)
I just checked both the heater hoses, neither were leaking
Old 02-25-2011, 06:39 PM   #7 (permalink)
Look very carefully by the thermostat. If you have a head problem, many times the first leak is right where the thermostat is. It is so close it will look like it is the thermostat.
96 reg cab, 5sp long bed 4x4: 10 plate, 3GSK, pump @15, AFC altered, K&N, gasket matched and ported exhaust manifold, 4" exhaust, gauges, KDP KO'ed, Dynatrac axles and hubs (don't go there, bad product, bad customer service), airplane landing lights, Dana Powerlok's front & rear, runs on WVO.
Baja is offline   Reply With Quote
Old 02-25-2011, 06:57 PM   #8 (permalink)
Try taking the belt off and running it. That way the fan and belt can't sling it everywhere.
'98 12v 2wd dually, SB DD, Detroit locker, 64/65/13 htb2, CPP 7x10's, 3kgsk, bhaf, 19*, 50 lbs boost
v8440 is offline   Reply With Quote
