bad fuel mileage - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 02-15-2011, 05:06 PM Thread Starter
bad fuel mileage
i recently got a 12 valve cummins and im not getting the gas mileage i was expecting, my truck has 4 10 gear ratio all the tires are inflated and it has a new air filter, i figure im getting about 10 miles to the gallon and thats being easy on it.besides that it runs fine any ideas?
kylecummins89 is offline
post #2 of 12 (permalink) Old 02-15-2011, 07:20 PM
zig
zig's Avatar
you don't need to start a second thread, just put this and A LOT more information about your truck in your first one...
1995 Extra Cab Long Bed 12 Valve...5 spd
KDP doing time, BHAF with heat shield, 4" Straight Pipe, No Fuel Plate, AFC tuned correctly, SDXII's, Gauges, custom headache rack and bed rails, Uniden CB with 5' Firestik
zig is offline
post #3 of 12 (permalink) Old 02-15-2011, 07:24 PM
zig
zig's Avatar
start with this:
year?
tire size?
tire type?
what kind of driving? (all town, country, highway, etc.)
you hauling anything?
what aftermarket parts do you have?
how many tanks have you checked mileage on, does it vary or is it consistent?
but put this information in the other thread
zig is offline
post #4 of 12 (permalink) Old 02-15-2011, 07:37 PM
Relic's Avatar
Just like I asked in your first tread. I'm not trying to give you a hard time, but fuel milege is affected by MANY factors. The more info given, the more help can be provided. Don't ask how long a piece of rope is.
1997 12v 3500 DRW 4x4 Ext Cab Long Box, Auto 320,000 KMS- Manual grid heaters wih Ford Solenoids. Back-up Camera. 4.10's.
Relic is offline
post #5 of 12 (permalink) Old 02-16-2011, 12:38 PM
Bump.
Come on, starting one thread is enough.
It's not going to get you an answer any faster, it's just going to annoy everyone.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #6 of 12 (permalink) Old 02-16-2011, 12:51 PM Thread Starter
Look I'm new at this so don't get upset
post #7 of 12 (permalink) Old 02-16-2011, 12:56 PM Thread Starter
It's a 97 long bed extended cab with 33x12.5 I live on longisland it's not very hilly here I never really go over 60 completely stock. I took the silencer ring out and turned up the injector pump up a tiny bit but I'm getting like 100 miles to a quarter tank or not even
post #8 of 12 (permalink) Old 02-16-2011, 01:12 PM
I would assume in a place like Long Island it's all stop and go traffic.
If so you're not going to get very good mileage, it's a heavy truck to get rolling.
I would expect you to get a maximum of 14.
BTW, I'm not upset at all.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
post #9 of 12 (permalink) Old 02-16-2011, 05:24 PM
Relic's Avatar
I have a very similar truck. A lot of stop and go for me. Lots of hills. Rarely get going fast enough for OD to acually kick in. If I can get 11 mpg, I think I'm doing good.
Relic is offline
post #10 of 12 (permalink) Old 02-16-2011, 05:29 PM
Relic's Avatar
You may wanna try a more accurate method of calculating mpg. Every time you fill up, stop as soon as nozzle stops. note the gallons amd miles for that time. Keep doing this for at least a month or half dozen fill ups. This will be much more accurate.
Relic is offline
post #11 of 12 (permalink) Old 02-16-2011, 07:56 PM
kayden101's Avatar
and dont forget to change that fuel filter. but stop and go traffic i would not expect it to be that high..... low teens prob.
oooooohhhh wow
kayden101 is offline
post #12 of 12 (permalink) Old 02-16-2011, 08:15 PM
Don't trust the fuel gauge for a MPG meter. It just tells you how empty you are, not accurate at all.
When you fill up, top off (fill till the nozzle clicks off) and reset the trip meter. Next time you fill up, fill till it clicks, and divide the trip meter reading by the gallon reading on the pump. That's your MPG. Reset trip meter, lather rinse repeat
Something that could be hurting your MPG is a stuck open thermostat. Does your temp gauge ever get up to the normal zone? If you replace it, go with a higher temperature one (210 or 215, maybe higher, others could tell you more than I could).
Also, you could very likely benefit from putting on an electric fan instead of the mechanical one. Or just take the old one off (but don't blame me if you have to wait on the side of the road for it to cool off).
Check and adjust your timing. The 12.5 degrees is not optimal for MPG nor power. If you bump it up (again, others have more specifics) you could probably boost your MPG again.
Note that these are all things that will give you roughly 1 to 5 percent MPG improvement (each), and won't make your truck suddenly beat a smart car or civic, but everything helps and things add up.
One more note: If you put in gauges, that would give us insight into how the engine is running and if it is not optimal.
94 2500 rclb 5spd 2wd, 5x.016, 14.5 4k GSK, 60 lb springs, 13125-OFEK
thecheese429 is offline
