'96 Automatic transmission will not shift from 1st - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 02-14-2011, 07:20 PM Thread Starter
I have searched the forums and could not find anything with the same problem.
I just got a '96 Dodge Diesel 4x4 that has a transmission issue. It will not shift out of first gear. It will shift in reverse and the transmission feels strong. The previous owner said that sometimes it will upshift if you shift it manually 1,2,3. I have tried to manually upshift it without success. It will do 25mph and when you let off the throttle it will just coast and when you reapply the throttle 25mph again.
The trans fluid is full and red. The only other issue the truck has is the fuel gauge doesn't work and is showing dead empty.
any help is appreciated
Thanks,
Mike
ebanezar is offline
post #2 of 12 (permalink) Old 02-14-2011, 09:51 PM
JeepsRcool's Avatar
I hand this Exact problem, drop the pan....
I had a broken front band apply lever.....
Your band, the anchor etc could be broken
1995 Dodge 12v ECLB Auto 4X4 240k KDP Tabbed, BHAF, 7x.012's, 16*s
JeepsRcool is offline
post #3 of 12 (permalink) Old 02-16-2011, 09:53 PM
Art
Your 1996 has a 47RE transmission.
For a 47RE transmission (that has a functioning 1st gear) to make a 1-2 shift, it needs the following things:
a.) The trans needs to have its front band as well as the front band actuating mechanism intact. This mechanism includes the servo, apply lever, band anchor, strut, adjuster. You can check the front band adjustment from outside the transmission. If you loosen the locknut and can turn in the adjusting screw more than two revolutions, it is loose. If it turns way in, there is trouble inside the trans.
b.) The trans needs governor pressure. Governor pressure is the hydraulic pressure equivalent of a speedometer. More speed = more governor pressure. A 47RE has its governor pressure created by the PCM via the governor solenoid. Electrical sensors and wiring could be a source of trouble as well as the solenoid itself. I suggest you put a 0-100 psi gauge on the governor pressure test port and take the truck for a test drive. If you have about 1.0 to 1.5 psi governor pressure per mph of truck speed, you are OK.
c.) The valvebody needs to have its spool valves able to move freely. As the governor pressure increases, it puts more force on the governor plugs. Once the force is high enough to overcome the TV pressure and spring that are pushing in the opposite direction, the 1-2 shift spool slides in its bore and makes the 1-2 shift. If the trans had dirty oil, the 1-2 spool valve may have gotten stuck. Additionally, IF the TV pressure was excessive, the 1-2 shift may not take place until very very late.
Hydraulic pressure tests will almost always help you pinpoint exactly where the trouble is. Is the governor pressure OK? Is the line pressure correct? Do you ever get hydraulic pressure at the front servo pressure test port?
WANTED: 1930 Dodge DD parts
lets go vintage drag racing:
Art is offline
post #4 of 12 (permalink) Old 02-17-2011, 05:04 PM
12v_cummins_power's Avatar
Art.... I have almost the same issue with my 96 12v... but I can manually shift from 1st, 2nd, and 3rd but I have no overdrive..
If I just put it in park then it will start in 1st, skip 2nd and go straight to 3rd..
Ive dropped the pan and there was no big pieces and everything seemed ok. I put a new pressure solenoid and sensor in it with a new filter and fresh fluid... Im sure its an electrical issue.
1996 2500 4x4 Laramie SLT 12v.,.. Ext. Cab Long Bed. 2.5" leveling kit, Silencer ring MIA, turbo plugged.
Soon to come: 5 inch Smeding exhaust, S&B intake, and more!
12v_cummins_power is offline
post #5 of 12 (permalink) Old 02-17-2011, 06:11 PM
I have posted on here before with a similar issue. When my truck gets below say 1/4 or 1/8 tank it will not shift out of first. Sometimes if i go real easy on the throttle it will shift but delayed or hard, than as soon as i put fuel in it the problem is gone instantly! Than on rare occasion when i am just starting out my truck will start to buck and stall out like i started in third gear. It is the crazyest thing i have ever seen. All i do is make sure i dont go below 1/4 tank i just figured i would mention it because i saw you said the fuel gauge does not work.
98 12v 4x4 auto club cab. banks kit
mopard3 is offline
post #6 of 12 (permalink) Old 02-17-2011, 07:49 PM
ham_r_down01's Avatar
Assuming the intermediate band strut didnt fall out, service manual points to a sticking governor.
97 Dodge 3500 SLT RCLB 4x4 CTD, South bend, Broken 4 Speed, MFILive
ham_r_down01 is offline
post #7 of 12 (permalink) Old 02-19-2011, 10:25 PM Thread Starter
I ordered a governor today and should get it in next week. I will let you guys know how it turns out.
ebanezar is offline
post #8 of 12 (permalink) Old 02-25-2011, 01:54 PM Thread Starter
I installed a new governor and governor speed sensor today. I took it for a test ride and no difference. As soon as it shifts into second it shift right back into first.
What would be next to do/look for.
thanks,
Mike
ebanezar is offline
post #9 of 12 (permalink) Old 02-25-2011, 01:58 PM Thread Starter
I am going to check the front band this evening. Is it up on the driver side mid ways down on the transmission?
Where is the governor pressure test port? I think I can rig up a gauge and take it around the neighborhood.
ebanezar is offline
post #10 of 12 (permalink) Old 02-27-2011, 06:51 PM Thread Starter
Update:
I checked and adjusted the front band. It was within specs, maybe just a hair loose.
I pulled the transmission relay out and it went into limp mode. 2cd and 3rd gear work great.
I also noticed another problem that might be a reason for the no shifting. The Gen light comes on and off. It is only charging between 11.6 - 12.5v. I took the alternator off and had it tested and it is fine. The truck also has new batteries in it. Could this be the reason it is not shifting?
ebanezar is offline
post #11 of 12 (permalink) Old 02-28-2011, 10:16 AM
spike00's Avatar
I know overdrive is linked with the charging problem on my 47rh idk about the other gears tho. The pcm doesn't know the truck isrunning and on the 47re it is all controlled by the computer so it may be a good place to start.
98 24v 5 speed 2wd
94 5 speed 94k miles sold
04.5 Laramie 66mm smarty mp8 and Goerend trans
spike00 is offline
post #12 of 12 (permalink) Old 03-05-2011, 02:05 PM Thread Starter
AND THE WINNER IS:
Bad ASD relay!
I was reading around on every message board I could find and someone posted they changed out the relay with the anti-lock brake relay and it fixed the problem.
ebanezar is offline
