Oil leak behind PS pump on a 96 - Dodge Cummins Diesel Forum
post #1 of 26 (permalink) Old 01-17-2011, 02:30 PM Thread Starter
I'm seeing an oil leak coming from somewhere behind the PS pump on our 96. I've checked the PS hoses and all seems sound. I degreased the engine and can see a trickle of what looks to be engine oil coming from somewhere just below/behind the IP. Since it's raining like crazy here, I'm trying to find a diagram of the left side of the engine. If anyone knows of a drawing or has any bright ideas, I'd sure appreciate it. Thanks.
1999 Dodge Ram 2500, QC/SB, 2WD, RV275s, Edge w Attitude, AFE Stage 2, AirDog 150, big line kit, BioDiesel, Suncoast TC and VB, Mark Wilson HD trans, Bilstein Shocks, B&W turnover hitch, Firestone airbags, RDS toolbox/60 gallon tank combo
gator_grabber is offline
post #2 of 26 (permalink) Old 01-18-2011, 12:47 AM Thread Starter
Now that the monsoon has passed, I'm still at a loss as to where the oil's coming from. Does anyone have a schematic/photo/whatever of what's going on on the driver's side of the 12V engine? Standing beside the truck, looking at the PS pump with a light, I can definitely see it moving down the side of the freshly cleaned block. Since we tow horses constantly with this rig, this needs to get sorted out as quickly as possible. Is there an oil pressure sensor in that area that may be giving up?
post #3 of 26 (permalink) Old 01-18-2011, 12:52 AM
pa coal roller's Avatar
it might be the tapped cover leaking
2012 cc dually 6speed, mini max, cooler delete, h&s intake horn, boost tube,5ich pipe,gdp big line kit Amsoil dealer since 2006
1996 12v 430000 miles. Built trans. 62mm hx 35 90hp injectors
pa coal roller is offline
post #4 of 26 (permalink) Old 01-18-2011, 01:01 AM Thread Starter
Tappet cover? Good suggestion, I've seen that with other engines. Let me do more of a search.
post #5 of 26 (permalink) Old 01-18-2011, 02:36 AM
ykdave's Avatar
tappet cover, oil pressure sending unit or the oil feed line to the injection pump and vac pump
Pretty much the only things that are going to be leaking in that area
ykdave is offline
post #6 of 26 (permalink) Old 01-19-2011, 12:40 AM
Dallasfire911's Avatar
also look around the vacuum pump if its leaking in a $15 dollar fix from cummins for a seal kit and only takes an hour or two to change them out
97' 3/4 ton custom exhaust, gauges, 36psi 35x,#0 plate, MANUAL fuel shut off, BHAF, 47re converted to a nv4500 w/ 450hp south bend clutch...
Dallasfire911 is offline
post #7 of 26 (permalink) Old 01-19-2011, 01:08 AM Thread Starter
If the vacuum pump is leaking, what oil comes out...engine or power steering?
post #8 of 26 (permalink) Old 01-19-2011, 07:39 AM
Motor oil.
'95 Dode Ram SLT 4x4, 47RH w/built converter (billet, carbon clutch, stall dropped),KDP fixed, BHAF, Z-Series Pyro/Boost/Trans temp
HeikkiH is offline
post #9 of 26 (permalink) Old 01-31-2011, 09:12 PM Thread Starter
Ok,
I finally got back to this little problem. After lots of degreasing, it appeared to be either the oil sending unit of whatever lies directly over it. Being the eternal optimist, I replaced the sending unit and hoped for the best...wrong! I'm really thinking it's the tappet cover at this point (rats), so I'm guessing the IP needs to come off to get at it. I'm used to the 99 I drive, so this is new territory. Any words of advice? Time to search again.
post #10 of 26 (permalink) Old 01-31-2011, 10:49 PM
smoky12valve's Avatar
ive got the same problem with my 95 what did it end up being?
95 Dodge 12 Valve - 62mm Turbo, Delivery Valves, 19 Deg. Timing, Air Dog 150 Fuel System, No Plate, 370 Marine Injectors, Built ATS Tranny (automatic). 5 inch Single stack.
smoky12valve is offline
post #11 of 26 (permalink) Old 01-31-2011, 10:55 PM Thread Starter
Not sure yet, but I'll post what I find. I'm currently looking for a good article on IP removal for the unfortunate.
post #12 of 26 (permalink) Old 01-31-2011, 11:53 PM
68bullittbuilder's Avatar
I had the same symptoms myself, leaking a cup or so of oil per day. After looking carefully and research I found it was the tappet cover leaking. Oh boy what a pain in the . Take your time. One thing I have to note is how it seems all the expensive replacement parts are right out in the open and the $10. POS replacement gasket is a few hours work to get to. Yes the injection pump must come out alone with the fuel filter housing. If you need help search this site before asking questions because this is fairly common. There are a number of reasons why it leaks, mine was just old (320k) and disintegrated. One thing that cannot be overstated...MAKE SURE YOU THOROUGHLY and I mean THOROUGHLY clean the IP shaft and the IP gear. If you don't you will damn sure regret it take my word for it. Good Luck with the fix.
68bullittbuilder is offline
