transfer case problems - Dodge Cummins Diesel Forum
Old 01-08-2011, 10:10 AM   #1 (permalink)
96cummins0916's Avatar
hearing popping in transfer case so i opened it up and found no fluid at all and this snap ring. i cant seem to find where the snap ring goes. anyone who can help? its probably four or five inches. Thanks
1996 2500 no plate, 4" tbe, 22* of timing, AFE intake, o ringed and studded head, 4k gsk, 60 lb valve springs, cpp 7x12, bd intercooler, ats intake horn, mack rack plug, billet 66/71/16, .025 dvs, airdog II 165, revmax billet input, converter, and vb
96cummins0916 is offline   Reply With Quote
Old 01-08-2011, 10:16 AM   #2 (permalink)
could you tell me which link to click to post a new message???????:confused
kevin71ch2 is offline   Reply With Quote
Old 01-11-2011, 01:48 AM   #3 (permalink)
Hmm. I know where it goes. You need a diagram, though, to put it back. IMO. If it were me, at the least, I'd do seals at this point.
If you were empty, bearings and chain would be my concern. A blue (and stretched) chain is not good, for sure.
What you took a pic of is referenced as a "synchro spring" in the manual. The three tabs it holds (two springs) are "synchro struts." It's role is played in between 2-hi / 4- hi.
kjax is offline   Reply With Quote
Old 01-11-2011, 02:01 AM   #4 (permalink)
WhiskeyRider's Avatar
Looks like the rear output main bearing retaining ring to me. Holds the bearing in place inside of the rear half of the case. Pretty sure the syncro thing your talking about has different dogs on the ring.
Item 19.
'96 2500 RCLB, 47RE, 241HD, BHAF, Tuned AFC, #8 Plate, KDP'ed, MBRP T-B 4"-5" tip, Silencer Ring Gone, Skull Valve Stem Caps. In the works: 5" Lift w/6" coils. Dually Convert. Highway Products flatbed.
WhiskeyRider is offline   Reply With Quote
Old 01-11-2011, 04:28 PM   #5 (permalink)
thanks for the help. since it was out for awhile what are the ffects of it being gone? otherwise why is it needed. its been makin noises for a couple months now wnd just took it apart. also if the shaft moves where the snap ring goes would that cause the shaft to move and chain to hop? thanks
Old 01-11-2011, 05:51 PM   #6 (permalink)
Basically its there to reduce the length of the shaft the bearing slides on. Inside the rear case half, there are dogs on the case that prevent the bearing from coming out of the case body, however the retaining ring keeps it in an even tighter spot in the case to prevent as much endplay on the bearing. Without it youll bet a bit of noise because the output shaft is going to move around more so than with it installed. Over time that excessive play can cause the chain to stretch out.
Old 01-11-2011, 07:29 PM   #7 (permalink)
ykdave's Avatar
been forever sinve ive had one of these apart, but 4-5" sounds like its the retaining ring that holds the outer planetary ring gear into the case (cant remember i these things were set up like that or not)
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
ykdave is offline   Reply With Quote
Old 01-11-2011, 07:31 PM   #8 (permalink)
Those have internal dogs on the ring, not external
