4wd shift actuator - Dodge Cummins Diesel Forum
Old 01-01-2011, 08:54 PM   #1 (permalink)
sm_lawrenceplus's Avatar
4wd shift actuator
well, found out the hard way that the 4wd vaccum shift motor( shift actuator) was bad. check al vaccum, and finally saw that the shift rod was bent. obviously from a bad shift. anyone know where to get a good unit? Was also wondering how often these things go bad. accually thinking of machining up a aluminum rebuildable unit.
1995 reg. cab 12v 2500 4x4, kdp fixed, all stock, for now.
sm_lawrenceplus is offline   Reply With Quote
Old 01-01-2011, 09:06 PM   #2 (permalink)
I just got one from Rock auto. 68 dollars. you can also get a posi lock one.
1998 AUTO RCLB 12v K&N muffler delete. 140K
dstang97 is offline   Reply With Quote
Old 01-02-2011, 01:47 AM   #3 (permalink)
ykdave's Avatar
i would suggest spending your money on a posilok or making a home brew posilok (theirs a few threads around here on it)
Its actually quite common for the CAD to fail. Its a pretty rinky-dink setup, even when its 'fully' engaged, its barely engaging the splines. So pretty much the first time it sees power while partially engaged it spits the collar off the splines, which pushes the fork and bends the shaft.
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
ykdave is offline   Reply With Quote
Old 01-02-2011, 07:12 AM   #4 (permalink)
blackimpala's Avatar
Not common in my world. 200K miles still the original CAD. With that said they do go bad,when mine dose I will go with the posi-loc cable.
Floyd
blackimpala is offline   Reply With Quote
Old 01-02-2011, 10:25 PM   #5 (permalink)
I had the same problem you did. My shift rod was bent and the diaphram was leaking. I went to pick-and-pull and brought my vacuum tester with me. All Dodge 4x4 trucks used these actuators. I found a really nice on on a 1500 that I brought home for $15. I tested it in the yard so I knew I had a good one. The truck shifts into 4x4 better than ever now.
I kept my old actuator in case I go the posi-lock route. If I do I'll mod the old actuator. I am also considering the Ford hub conversion which will get me conical bearings (no more unit bearings), locking hubs (no more CAD), and dual-piston calipers (better braking). I haven't decided whether or not I will do that conversion yet.
1997 CTD extended cab 4X4 5 speed. Towing package, SLT, BHAF, 4" straight exhaust
Bought 4/28/07
bob95065 is offline   Reply With Quote
Old 01-02-2011, 10:47 PM   #6 (permalink)
ykdave's Avatar
x2
you will find them on all 4x4 dodges up until the 3rd gens when they started using AAM axles and ditched the CAD setup.
You might even try the older jeeps as they used a CAD too, but being D30/d35 axles it may be a whole different (smaller)unit, but worth a shot
