👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Hello to all. New account so bare with me . I have a 2003 Dodge Ram 2500 5.9l Cummins. I was wondering if i’d be able to pass smog straight piping the exhaust? I pass smog normally but want to go ahead and straight pipe. I know there’s no o2 sensors on the systems so there should be no problem...22 replies 400 views
1998 ram 2500 12 valve ac not working. Power at fuse 9 in cab junction box power at fuse J in engine bay junction box and power at relay pin 30. Metered continuity from Fuse 9 to pin 86, and metered continuity from PCM C1 to pin 85. No power at pin 86. Jumping relay pins 30 to pin 87 Will engage...8 replies 151 views
If your like me and had the code p04db come up after installing an AFE intake it annoyed me like crazy and being that I live in California it prevented me from getting a smog I sat the stock intake and the AFE intake side by side and went threw them both throughly and found out that the CCV...10 replies 3K views
Howdy folks, Can anyone get me started with a baseline rear caster setting on my truck? It's a 2018 2500 4X4 with a 4" lift. Looking at the position of the bolts, something is definitely off here. Rear passenger side of the truck sags an inch or two. With the steering wheel centered, the...8 replies 180 views
Recently been having some trouble with my transmission, but specifically the torque converter I think. When driving home under light throttle, my trans will lock the converter around 45mph and begin to shutter and buck unless I speed up. Any ideas on what it could be? Slipping converter maybe?0 replies 22 views
