👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
I'm thinking of looking for a decent flatbed to put on my 97 2500 SRW. When looking at a used one, without knowing what truck it came off of, how can I know if it will bolt on to my truck? Thanks for any advice you could throw at me.1 reply 67 views
I need the bandclamp for the crossover EGR pipe. The Mopar part number is 68450852AA. On the mopar site it is listed for $132. Are there alternatives that I could get for a lower price? Seems a bit much for a small clamp like that2 replies 81 views
Now that my Thuren suspension is on I now have the chance to do 37s. My smog is factory and has no issues, I am not towing anything for now. I have been running 295-70-18 Michelin Defenders for a long time now with no issues and even did tow a 8500 pound TT. Going to 37s will add 15 pounds on...67 replies 1K views
Just put my first diesel motor in. 6.7 Cummins in a 2013 ram 2500. Doesn’t want to start seems like it’s not getting fuel but when it’s cranking and once in awhile when it starts shortly there’s a very loud banging seems to come from lower passenger side of motor. Also when the key is on but...3 replies 150 views
I have a 2006 Dodge Ram 2500, mega cab with 4 wheel drive and the 5.9 cummins. I am in need of tires here soon, as the tires that are currently on the truck are 13 years old and have a screw in two of the tires. No one will repair or rotate the tires because of their age and wear, so I am trying...50 replies 1K views
