12 valve stall out issue - Dodge Cummins Diesel Forum
Old 12-28-2010, 01:20 AM   #1 (permalink)
tbnavspec's Avatar
I have a 96 2500 with an automatic that has recently begun stalling out at inopportune times. when i slow the truck down and its still in gear, it tends to just lose all RPMs and die. i'll shift into neutral similar to driving a standard and the RPMs will stay at normal idle levels. when i'm driving everything is fine, but doing normal low speed operations i.e. parking, uturns, 3 pint turns etc. its pretty annoying. it will always crank over again and start up, but i would really like to remedy this problem. If anyone has any ideas as to what the issue might be, It would be greatly appreciated. thanks
tbnavspec is offline   Reply With Quote
Old 12-28-2010, 01:32 AM   #2 (permalink)
ykdave's Avatar
Is it the torque converter clutch staying engaged and killing the engine or is it just the engine dieing on its own?
Couple be just a small air leak in the fuel line, or too low of an idle
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
ykdave is offline   Reply With Quote
Old 12-28-2010, 02:02 AM   #3 (permalink)
tbnavspec's Avatar
it has been a lot slower to come up to operating temp in the morning, but like i said when its running and in neutral it will idle. when the transmission is engaged in drive or reverse is when the stall out occurs. Another thing i have noticed is that it is more apt to stall when the wheel is at full lock or being turned in either direction. i am guessing that is because the power steering pump is drawing power from the engine.
Old 12-28-2010, 02:19 AM   #4 (permalink)
BDGibson4's Avatar
Location: Punxsutawney or Pittsburgh, Pa depending on the part of the week
I'm not an automatic expert but it sounds like your torque converter is engaging to low and stalling you out. (The fact that it does it when turning adds to this thought as it would require more torque to propel the vehicle forward, hence stalling more at idle.)
2012 2500 Mega Cab Laramie Limited will all the factory fixins
I'd rather have my straight six, than your BENT eight.
BDGibson4 is offline   Reply With Quote
Old 12-28-2010, 10:02 AM   #5 (permalink)
blackimpala's Avatar
What is your idle? It should be 850-900 in drive with A/C on. You just could be too low.
Floyd
blackimpala is offline   Reply With Quote
Old 12-29-2010, 12:42 AM   #6 (permalink)
tbnavspec's Avatar
typical idle RPM in Neutral is around 800, and slightly lower when idling in gear and rolling. I seldom use A/C, more of an open window guy
Old 12-29-2010, 12:47 AM   #7 (permalink)
Hardymanracing's Avatar
Just bump the Idle and you'll be fine
96 3500,nv4500 swap, racked barrels,27* timing,40hp inj,HE351Ve,4"exhaust,half cut dv's ,no plate, afc tuned, 4k's, 80lb springs, titanium keepers retainers.
Hardymanracing is offline   Reply With Quote
Old 12-29-2010, 12:57 AM   #8 (permalink)
ckanderson's Avatar
raise it, you would be supprised at how easy it is for them to die from a low idle. mine is at 750 in gear with a/c on
03 qcsb 4wd Thuren suspended, King 3.0's.
Big thanks to CJC for parts advice and great prices!!!
ckanderson is offline   Reply With Quote
Old 12-29-2010, 11:16 AM   #9 (permalink)
tbnavspec's Avatar
I appreciate the many responses and advice from all. Just a little unclear on how I would physically adjust the idle on the truck, but I'm assuming it will have to be done somewhere on the injection pump.
Old 12-29-2010, 11:29 AM   #10 (permalink)
before i adjusted the idle on my truck (would idle at 750 with ac off) I could burp the throttle when in gear and the truck would stall lol. What rpm is the truck when you put it in drive? you could be having the same problem as me where the torque converter is staying locked up and is acting like a manuel truck when you come to a stop and dont push in the clutch.
Enigami is offline   Reply With Quote
Old 12-29-2010, 11:51 AM   #11 (permalink)
Let me google that for you.
Ram Diesel Problems
Floyd
The Following User Says Thank You to blackimpala For This Useful Post:
tbnavspec (12-29-2010)
Old 12-29-2010, 02:45 PM   #12 (permalink)
tbnavspec's Avatar
Did adjusting the idle level solve your issue? your symptoms sound almost identical to mine.
