sqeaking when i downshift 5 spd - Dodge Cummins Diesel Forum
Old 12-27-2010, 02:59 PM   #1 (permalink)
its ben happenin now for a few months not sure wht it is..it only does it at a high rpm hwne downshifting. not sure maybe throwout bearing, whenever its called out and i just start my truck i can sometimes here my throwout bearing rattling a little bit may be normal thou for usual wear when its cold
94 2500 green single cab long bed 5 spd. 20 inch black wheels nitto trail grapplers,hybrid turbo,0 plate,BHAF,pump fully tuned, 17* timing, ARP's and o-ringed head
smken u is offline   Reply With Quote
Old 12-29-2010, 11:48 AM   #2 (permalink)
bump...???
Old 12-30-2010, 12:19 AM   #3 (permalink)
kfisher's Avatar
could be your throwout.
that noise will vary as you engage the clutch and increase rpms.
does the noise change when you engage or disengage the clutch peddle not so much when you shift but the actual peddle?
if you do replace the throwout its always a good idea to throw in a new pilot bearing as well. there cheap and easy to put.
97 EC, LB white, smoked cab lights, 4 inch skyjacker firestone bags and 37s on 17s. afc tuned, #0 slid where it needs to be, boost elbow @ 37lb, BHAF, 4 inch straight pipe to 6inch single stack, 100hp injectors, gauges (boost/egt) valair single 450hp 850lb ft
kfisher is offline   Reply With Quote
Old 12-30-2010, 12:25 AM   #4 (permalink)
can you make the squeak happen everytime? if you can try making it happen and push slightly on the clutch pedal. if it wont do it while u have slight pressure on the pedal its most likely the throwout. If it still does it it could be the pilot bearing or you could have lost a spring off the clutch and its causeing a light vibration in the clutch disk.
most likely its the throwout.
Enigami is offline   Reply With Quote
